SolaraGuy.com • View topic - Need help?
Need help?
Need help?
Postby solara driver99 » Thu Nov 29, 2007 8:37 pm
I have a 99 solara with 133,000 miles on it and all i have done is change spark plugs. And Im have to have the engine pulled out to put in a rear main seal and what else should i do to it since the engine going to be pulled out?
solara driver99
Postby Eye8Pussies » Thu Nov 29, 2007 8:51 pm
may as well do the axle seals then I guess
otherwise...not much else that you can't do with the engine in the car
Postby Mole » Thu Nov 29, 2007 10:28 pm
are you sure you have to pull out the engine to do the rear main seal?
Postby solara driver99 » Fri Nov 30, 2007 3:15 pm
i work at a shop called hometown tire and by looking at it that lookes like the easiest way to do it.
solara driver99
Postby Eye8Pussies » Fri Nov 30, 2007 3:24 pm
it's pretty easy....
BUT...if you work at a shop, then why not just drop the tranny ala shop manual instructions?
it saves a lot of hassle in the fact that there is a lot less things to disconnect and reconnect then- wire harnesses, hoses, etc.
