SolaraGuy.com • View topic - studs on rear hub....
Postby sahuddleston » Sat Dec 08, 2007 1:45 am
so i took off my wheels today and saw that a few studs on my rear hub had been cut off about half an inch. looked like 2 on each side. i am using spacers now so it isnt affecting my wheels. i will be getting new wheels and wont be using spacers. can i take my car to any repair shop and have new studs put in or is this something for the dealership to do? thanks guys.
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby Toy1mzfe » Sat Dec 08, 2007 3:53 am
yea repair shop should be able to do it.
i just got my 10 studs replaced with extended ones. They should chare u an hour job. cost me 70 bucks
Postby Midias » Sat Dec 08, 2007 7:36 am
Yea any shop can do it I personally did it my self in about 2 hrs. But I had a good press for the studs
Postby TadS » Sat Dec 08, 2007 10:13 pm
A good shot with a big hammer will knock them out. You’ll need an impact to pull the studs through. Get a couple of extra lugs in case you bugger a few up pulling the studs through the hubs. Easy work for a DIY if you have the tools.
TadS
Postby ThatVietGuy » Sat Dec 08, 2007 11:02 pm
Man, I replaced mine the ghetto way.
I flipped the rotor around and tightened the new stud with a lug until it pressed itself in :lol:
ThatVietGuy
