SolaraGuy.com • View topic - CEL shows bad O2 sensor, anyone have pics of fuse box area?
Postby 2ksev6 » Mon Dec 17, 2007 11:07 am
Hello,
I've got a check engine light, it first came on 3 days ago in a heavy rainstorm. Perhaps puddle induced. Initially there was a weird smell that almost smelled like burning clutch, but different, can't really describe it any better than that. Burning fluid is a possibility.
Autozone scanned it, said it was an Oxygen sensor. Maybe the guy said bank 1. He said if I reset my ECU it might go away, and if it comes back it may be time for a new sensor. Also said it's running in warm up mode which is costing me gas mileage.
I pulled my "Main" fuse from the fuse box in the engine bay thinking that that's how to reset the ECU. It was out for probably about 5 minutes, but when I restarted the car the CEL was still there. Do I perhaps need to disconnect the negative battery cable, or is it more likely that I have a problem?
One more thing I noticed is that there is some sort of a wire with a ribbed plastic surround and some sort of electronics connector behind the engine bay fuse box, toward the bottom of it, that's just in front of the strut tower, so it's in between the strut tower and the fuse box. It wasn't connected to anything, does anyone know what that is or have a pic of that area so I can see what it's supposed to go to? I did a search but couldn't find one.
On a side note:
I was going to have a tune up done soon, so this is pretty good timing. I have about 121,000 miles on it, are O2 sensors supposed to be replaced at this point? And what else should I look at having done since I'm about to drive across the country? Thank you, and sorry for the long message. :D
TRD shifter, TRD springs, KYB struts and rear strut mounts, Stillen Cross Drilled and Slotted Brakes and pads, Whiteline RSB, tint, and a decent stereo, 17x8 TSW Kyalami rims on Hankook tires
2ksev6
Postby Chinky420 » Mon Dec 17, 2007 11:39 am
what's the code? (P0135?)
to reset the ECU the neg terminal on the battery must be disconnected for ~10 min.
Chinky420
Postby 2ksev6 » Mon Dec 17, 2007 12:00 pm
Sorry, I didn't get the code from him. Is there a range of problems or something?
2ksev6
Postby DatSRBoi » Mon Dec 17, 2007 12:21 pm
Common on a few solara. Just buy a new rear sensor and throw it on. Seems like allot of people get that here even me.
Postby ASG14 » Mon Dec 17, 2007 3:28 pm
Eye8Pussies just had his replaced (108k miles) at my mechanic's under car's warentee. The rear 02 on my '96 Camry went at about 90k miles. Common.
ASG14
Postby 2ksev6 » Tue Dec 18, 2007 6:01 pm
Well I disconnected and reconnected the battery to reset the ECU about 24 hours ago. Did so in the manner described above (Thanks and stay high, Chinky420).
No CEL yet, so it looks like that was it. I guess I must've gotten something electronic wet, or maybe water went up into the intake and out the exhaust and made that smell or something, which is weird because the intake is stock, but whatever. Anyway, unless it takes longer for the problem to resurface it looks like all is well so thank you all for the help!
2ksev6
Postby Ruski » Tue Dec 18, 2007 6:05 pm
if the ecu flacked the sensor good. it will mostly likly come back i repalced all 3 sensors on my solara. and then about 60k later the front sensor went out agian i kept resetting ecu but came back at diff times,each time. just replace it and get it over with. plsu the car runs in safe mode when the codes are present
