SolaraGuy.com • View topic - GEAR BOX LIGHTS
GEAR BOX LIGHTS
GEAR BOX LIGHTS
Postby g00nsquaddd » Fri Dec 21, 2007 3:26 pm
the lights on my gearbox are out (P..N..D..etc)
what fuse do i need to change?
( '99 SLE)
do not post in caps. it means you are yelling.
g00nsquaddd
Postby NeFaRiOuS_SLE » Fri Dec 21, 2007 6:13 pm
Wow, very informative :o .... Didn't know how to change it before!
Seriously though, post in the right section; tutorials is for showing us how to do something.
Did you try looking at the bulbs first? Are any other things in your car not working?
Mods, you know what to do.
Postby woa_its_j3ff » Fri Dec 21, 2007 8:07 pm
maybe its dark out.
and your lights aren't on.
ha.
Postby NeFaRiOuS_SLE » Fri Dec 21, 2007 8:44 pm
^Well he asked me on AIM and a few other things weren't working, so I'd say it's a fuse.
Postby neo6205 » Sun Jan 20, 2008 10:04 pm
I have the same problem of the gear selector lights being out. Odd thing is if I tap on it a few times they'll come on for a little while. I was running a power cable through there to the trunk for some amps and spent a little time seeing if I could take apart the gear selector to find if it was a loose plug or something but they dont seem to be made to be opened.
neo6205
Postby woa_its_j3ff » Sun Jan 20, 2008 10:06 pm
neo6205 wrote:I have the same problem of the gear selector lights being out. Odd thing is if I tap on it a few times they'll come on for a little while. I was running a power cable through there to the trunk for some amps and spent a little time seeing if I could take apart the gear selector to find if it was a loose plug or something but they dont seem to be made to be opened.
its not hard to pop out the gearselector, just take a flathead, and stick it between black part of it and the side and pry up, it should pop out..
Postby Turbosolara » Sun Jan 20, 2008 10:15 pm
THERE IS NO LIGHT IN THE GEAR BOX!!!!!!
Postby NeFaRiOuS_SLE » Mon Jan 21, 2008 3:56 pm
^ Gear box? HE... MEANT... SELECTAAAAAAAAAAAAAA!!!!
(Read what the mod inserted on the first post. Caps means you're yelling).
Postby NeFaRiOuS_SLE » Mon Jan 21, 2008 4:00 pm
We'll let you go this time, but try not to re-activate threads more than a month old (2 weeks at the most). I traced HIS problem back to a fuse since a few other things aren't working in the car (e.g. cig lighter), but if its your gear selector only, seems like either something wasn't grounded correctly for your amp, interference in the wire, or probably the bulb itself is coming loose. As far as the gear selector light, I'm not sure how to change it since mine are still working (even if it's not, I always use the indicators in the gauge cluster anyway).
Postby DrLove » Mon Jan 21, 2008 10:42 pm
Mine stop to light up sometimes! Then I give some hit on it and it works again. It's the last place that I need to put white LED'S. I'm gonna plug the matrix LED from another place, (the cig).
Im sure it will looks amazing with white LEDs, the HVAC and gauges looks superbs.
Im gonna send pics soon I will have time to do the mod.
Mazda 6 2010 6 speed black GS
DrLove
Postby DrLove » Fri Feb 29, 2008 6:55 pm
I changed mine today for a 1W white LED, it's pretty hard to remove it..and much more to plug it back...really it tooks me 30 mins and I was kind of nervous when I lost my LED in the gear box lol..but I've find it and now it's working..I cant do a tutorial for this..it's just a pain to remove the center console and all for a so little bulb.
DrLove
