SolaraGuy.com • View topic - Strange knock when decelerating
Postby Brettboy » Sun Dec 23, 2007 5:35 am
I'm having this knocking sound when I let off the gas, especially at lower speeds (under 35 mph). It sounds like it is coming from my front right wheel. Anybody have any guesses as to what this could be? Thanks.
Brettboy
Postby DatSRBoi » Sun Dec 23, 2007 8:49 am
Could be bushings. I would start with that. Then look at your bearings and then fender undercover to see if its loose. If you still cant find the problem check for loose bolts especially around the brake area. From there move onto the Drive shaft and the spline.
