SolaraGuy.com • View topic - engine surges, bad TPS sensor?
Postby 1gSE » Thu Jan 17, 2008 8:18 pm
it just started happening randomly after my 12 mile trip into town. It does it mostly at idle... it drops to about 800 rpm, raises to about 1100, then it idles like it had a big cam in it. Also if i'm cruising in any gear around 2100 rpm, it feels like the your going stabbing the gas pedal and letting go real. It's beyond annoying. My CEL came on, flashed for about 30 seconds, and then stayed on. I would have gotten the code checked, but of course..this happened when everything was closed. Any ideas? don't say the search button cuz i already tried that
Solara-M62 @ 5.5psi
1gSE
Postby AllShowNoGo » Thu Jan 17, 2008 8:24 pm
My car did something very similar to that awhile ago. When i opened the hood i noticed my intake was falling off..lol
AllShowNoGo
Postby 1gSE » Thu Jan 17, 2008 8:30 pm
AllShowNoGo wrote:My car did something very similar to that awhile ago. When i opened the hood i noticed my intake was falling off..lol
i had that happen about a month after i got the car. That was the first thing i checked, but thats not it this time
Solara-M62 @ 5.5psi
1gSE
Postby Akfahad » Fri Jan 18, 2008 3:09 pm
could be the TPS or could also be the IAC (idle air control valve). If that is it, it might just need a cleaning. how many miles are on your car? I just ended up replacing my TPS around 100k to give you an idea.
Postby 1gSE » Fri Jan 18, 2008 3:59 pm
i'm at 133k. I went to O'reileys (sp?) earlier and got the CEL scanned. I can remember the code...looked like p0404 or something, and the guy said something about the EGR valve, excessive blah blah blah. I took it to the same shop that did my timing belt and the guy there said a lot of things can cause an egr code and it would take some time to narrow it down, but the earliest they could look at it is tuesday, and i just can't go 4 days w/o my car
Solara-M62 @ 5.5psi
1gSE
Postby Solarizona » Fri Jan 18, 2008 5:13 pm
I had the same thing on my old solara. Changed the EGR valve and completely fixed the surges.
Solarizona
Postby 1gSE » Fri Jan 18, 2008 7:19 pm
sweet, how much did it cost you? Is it worth paying someone to fix or can i do it myself? I work with engines daily, but buying new parts doesn't come outta my pocket...so i'm a lil more cautious with my own hehe
Solara-M62 @ 5.5psi
1gSE
Postby Solarizona » Sat Jan 19, 2008 12:42 am
It cost me right around $150. I wish I had done it myself. I don't think it took the mechanic even 15 minutes!
Solarizona
Postby 1gSE » Sat Jan 19, 2008 2:20 pm
i pulled the egr valve off this morning and it seemed to work fine. No binding or anything. I cleaned the pipe out and it have any carbon build up. So i guess it's something else. Time to bring out the multimeter :x
Solara-M62 @ 5.5psi
1gSE
Postby TqMnster » Tue Feb 12, 2008 8:32 am
Did you eveer find out what the problem was? Mine is doin this also. Runs smooth but when you pul up to a stop sign it drops to around 700 then back up to 1000 then up and down until you take off..... No CEL though....
2000 Solara - Red SLE-V6 w/ Conv. Top
2000 Dodge 2500 - Cummins Turbo Diesel..... Far from stock.....
TqMnster
Re: engine surges, bad TPS sensor?
Postby Gregtrd » Tue Feb 12, 2008 10:01 am
1gSE wrote:it just started happening randomly after my 12 mile trip into town. It does it mostly at idle... it drops to about 800 rpm, raises to about 1100, then it idles like it had a big cam in it. Also if i'm cruising in any gear around 2100 rpm, it feels like the your going stabbing the gas pedal and letting go real. It's beyond annoying. . I would have gotten the code checked, but of course..this happened when everything was closed. Any ideas? don't say the search button cuz i already tried that
"My CEL came on, flashed for about 30 seconds, and then stayed on"
its an intermitten problem with one of your fuel injectors, i fix a 1997 camry with that same problem, what you describe is what i recall with the camry i fixed. in my case it was one the front three injectors, it would suck if it was one of the rear three injectors. when you fine the problem let us know
Gregtrd
Postby 1gSE » Tue Feb 12, 2008 10:31 am
oh yeah, i almost forgot. It's the egr valve. I pulled the vacuum line off and it instantly ran perfect...plugged it back in...started running like ass. But since i'm limited on parts stores here (one checker...one o'riley) i'll be ordering it online.....plus it's about $100 cheaper than checker
Solara-M62 @ 5.5psi
1gSE
