SolaraGuy.com • View topic - What RPM does fuel cut off?
Postby Fletch » Mon May 19, 2003 8:24 pm
I searched this topic and can't find any answers. Redline is 6200 RPM but I think I may have gone a few hundred RPM beyond that a couple times. Does anybody know what RPM fuel cut off or the rev limiter is at? I don't want blow my 100,000 mile engine trying to find out.
2006 Legacy GT spec.B
Fletch
Postby NASTY » Mon May 19, 2003 8:28 pm
100 000 miles? whoa thats alot!
i could be wrong, but im pretty sure fuel cutoff IS at 6200
'01 SLE V6
NASTY
Postby Yanks0114 » Tue May 20, 2003 10:51 am
I think the fuel cut off is 6250, I wouldn't worry about over reving as long as you aren't racing that much, which you shouldn't be doing on a high mile engine anyways
Postby zinie » Tue May 20, 2003 2:04 pm
100K just broken in.. If I can 250k out of a areostar and no major rebuild. I figure 300k to 350k out of my Solara sle. :lol:
zinie
Postby Fletch » Tue May 20, 2003 3:04 pm
Yanks0114 Posted: Tue May 20, 2003 9:51 am Post subject:
Maybe I exaggerated a little when I said I went a few hundred RPM beyond 6200, it was probably more like 50. I bought the car used with 97,000 miles. I know the oil was changed regularly and I just had the timing belt / water pump done. I figure it's good for at least another 100,000 miles of normal driving, 50,000 miles of hard driving.
Fletch
Postby adam2562 » Tue May 20, 2003 3:50 pm
i got 114k on mine and ran 15.1 with almost no performance stuff done
Adam - 99 V6 5spd 165k -SOLD
adam2562
Postby Yanks0114 » Tue May 20, 2003 4:37 pm
No question the car will last long, but its just a lot of stress if you continually running it hard.
Postby adam2562 » Tue May 20, 2003 4:38 pm
i run mine hard daily... its running good.. honestly my friends are amazed with toyota quality with all 4 toyotas i've owned..
adam2562
