SolaraGuy.com • View topic - How to remove this
How to remove this
How to remove this
Postby BlKSo|aRa » Tue Jan 22, 2008 1:51 pm
Sorry im totally new to car, but willing to learn :D . Any1 know how can i remove the white stripe on the side of the car, and do i have to buy anything to put on the car after it been removed? Thank you
Also how do i remove the toyota, Solara n the logo badge.
BlKSo|aRa
Postby woa_its_j3ff » Tue Jan 22, 2008 1:53 pm
that's pinstripe. just take a hairdryer, heat it up and gently peel away with your fingernail. DONT use a ruler or credit card or even worse a razer blade, heat it up so it get soft and pliable, then scratch away GENTLY with finger :)
Postby d4008 » Tue Jan 22, 2008 1:54 pm
is it painted on or the autozone pinstripe
its almost done, cant wait til spring.
d4008
Postby BlKSo|aRa » Tue Jan 22, 2008 2:14 pm
i think its pinstripe cuz it kind of pilling off
BlKSo|aRa
Postby AllShowNoGo » Tue Jan 22, 2008 2:25 pm
for the badges just use hairdryer and dental floss.
AllShowNoGo
Postby d4008 » Tue Jan 22, 2008 2:32 pm
cool i just took my stripe off just scratch a corner off just enough to grab with your fingers then get a cup of hot water and poor on the stripe as you slowly pull off. should slip right off but dont rush it.
d4008
Postby Jakecallun20 » Tue Jan 22, 2008 3:12 pm
Yeah, the badges just heat them up with a hair dryer and slide some fishing wire or dental floss behind them and gently pull them away. Be careful about your decision tho. When I did mine for the first time, there was horrible scratches and marks left over from where the symbols used to be (not from me removing them) because my car was never garaged by the last owner.
Postby akora12 » Tue Jan 22, 2008 3:13 pm
Goo gone or bug/tar remover also helps, especially if the stripe has been on the car for a few years. Since your car is a dark color, the paint under the stiping may be darker since it hasn't been exposed to the sun, but give it some time and it will blend in eventually.
Postby BlKSo|aRa » Tue Jan 22, 2008 3:24 pm
i just start removing part of the stripe but man it look ugly the stripe came off but the sticky stuff stay on ...... :x is there any thing that i can pour on there to get rid of the sticky stuff?
BlKSo|aRa
Postby woa_its_j3ff » Tue Jan 22, 2008 3:30 pm
BlKSo|aRa wrote:i just start removing part of the stripe but man it look ugly the stripe came off but the sticky stuff stay on ...... :x is there any thing that i can pour on there to get rid of the sticky stuff?
like Akora said, goo gone or use some rubbing alcohol very lightly or I even used windex mixed with water. do it somewhere warm, int he cold itll be tough to get out in my opinion.
Postby SolaraBlue » Tue Jan 22, 2008 3:49 pm
dont pour anything on there :lol:
use a LITTLE goo-gone and some elbow grease and itll come off eventually. then wax the area the pin stripe was, after that you shouldnt have any sign the pin stripe was ever there... a good wash afterwards would help as well.
Postby Jai_Jai_Binks » Tue Jan 22, 2008 6:12 pm
for a CLEAN job, wait till summer, on a hot summer day..take a hair dryer after the paints' already warm...will be whole lot easier than doing it in the winters.
Postby Ivanhoe » Tue Jan 22, 2008 6:48 pm
Jai_Jai_Binks wrote:for a CLEAN job, wait till summer, on a hot summer day..take a hair dryer after the paints' already warm...will be whole lot easier than doing it in the winters.
I did mine last week in 30 degree weather, I was done in 10 minutes!.....as long as you have a hair dryer, it doesn't matter what the temp is.
Ivanhoe
Postby BlKSo|aRa » Tue Jan 22, 2008 6:51 pm
I did mine last week in 30 degree weather, I was done in 10 minutes!.....as long as you have a hair dryer, it doesn't matter what the temp is.[/quote]
can u take some picture, i want to see wat it look like thanks
BlKSo|aRa
Postby Americanctm10 » Tue Jan 22, 2008 6:55 pm
ya it'll work but since the paint under your badges hasn't received as much sun as the paint surrounding it you will have two shades of paint around your badge, light and dark.
The summer heat would help bake the paint where your badges use to be so it looks better, i'd do it in the summer or spring time like jai said.
Americanctm10
