SolaraGuy.com • View topic - Solara turn signal problem
Postby knightbird123 » Tue Jan 29, 2008 2:38 pm
I own a 2003 Toyota Solara 4 cly. My car is always kept outside in the cold. Yesterday, I started up my car and realized that the turn signals <- -> on the dashboard were not lighting up green. When I put the turn signal stick located on the left side of the steering wheel in the up position or down position, nothing happpened meaning there was no "clicking" sound and the turnsignal lights wouldnt light up. The left and right turn signal changers were completely inoperable. After the car heated up and I drove it for about 4-6 miles they magically began to work again perfectly. Obviously some part is going bad or the weather has affected some device. Any suggestions as to what caused this to happen?
knightbird123
Postby NeFaRiOuS_SLE » Tue Jan 29, 2008 3:18 pm
Probably a bit of condensation messing with the fuses; sometimes even re-seating the fuse would work. Worst case scenario, your hazard switch is probably dismounted (happened to me once, but then again it was because I forgot to reconnect it after changing its backlight :roll: ).
