SolaraGuy.com • View topic - 01 solara 5SFE PO420
Postby bigbodychevrolet » Sat Feb 02, 2008 11:30 pm
I have a 01 solara with 2.2 about 135k and a reoccuring PO420. I replaced the rear cat and now the same prob exists don't know what it is now exactly. the a/f sensor, rear o2 sersor, or precat, exhaust leak? I don't hear a leak, the data on the scan tool only has 02s12. which bank or sonsor is that? Its only reading one. when i do 02 sensor tests it can't find any info for the rear sensor. the voltage it does read on the 02s12 is very erratic .67 then to .04 in seconds i don't think this is normal. i'm thinking of just replacing all three the sensors and precat. I was also wondering if i could replace the precat with a header. anyone make one thats worth having? would a header keep my light on? the light really bugs me. I'm getting about 17mpg right now constantly. same driving habits have always had was getting around 24 city keep track of that stuff. any help would be appreciated. thanks
bigbodychevrolet
Postby Turbosolara » Sun Feb 03, 2008 1:48 am
the cat you replaced, is it OBDII compliant? i believe front and back are both AF sensor, depends if your car is california edition or state emission. i would suggest you go pick up a factory service manual for more precise diagnosis.
i think there is only two sensors btw. one is on the header and one is next to catalytic converter.
http://www.aa1car.com/library/p0420_dtc.htm
Postby bigbodychevrolet » Sun Feb 03, 2008 10:41 am
pretty sure it is, had an Exhaust shop order it and weld it on for me. I'm going to be really pissed if its not, i'm gonna go down there and see. I have 50 state emmisions. Thanks
bigbodychevrolet
