SolaraGuy.com • View topic - Need a new tranny I think?
Postby rewmomi » Mon Feb 04, 2008 8:58 am
I was driving the car and the gears would not change utill it was about 4k rpm so i was at a stop light and the gear was on drive and it would not go. So I put it in park and then put it in drive and it worked but it would not pass the third gear. When I took the dip stick out from the tranny oil it was black and smelled like it was burned. I just got the car so I dont know when the last owner actually did a tranny oil change. So any suggestions on where to get one?
rewmomi
Postby Ruski » Mon Feb 04, 2008 10:26 am
so take it to a tranny shop and have them check it out
Postby synenergy52 » Mon Feb 04, 2008 7:39 pm
How many miles you got? 4 cyl or 6?
MY06 E46 BMW 325ci 5MT, Sport Package, Active Xenon, body colored front reflectors.
MY99 Solara SLE V6 4AT (all the SLE junk)
synenergy52
Postby rewmomi » Thu Feb 07, 2008 7:14 pm
I got about 148k on it and its a 6
rewmomi
Postby 99V6solaraSE » Thu Feb 07, 2008 9:24 pm
was ur car warmed up already?
i noticed that when i drive my car at first from a cold start it actually shifts at higher rpms til its warmed up
99V6solaraSE
Postby hskrsolara » Thu Feb 07, 2008 11:07 pm
99V6solaraSE wrote:was ur car warmed up already?
this is common to most toyotas. helps to warm the transmission/ protect it... actually my old camry would never shift into overdrive unless it was warmed up for at least a good 5 minutes.
hskrsolara
Postby rewmomi » Fri Feb 08, 2008 12:35 pm
Yeah my tranny is gone I did a total fluid change and it still not shifting. Yes I did wait till it warmed up. I am going to go again and mess ith the over drive before getting another tranny.
rewmomi
Postby SpeedySolara » Sun Feb 10, 2008 4:59 am
Speak to whoever sold you the car before speaking to a transmission shop. Was it an as-is sale/purchase? How long ago did you buy it? Chances are if they didn't bother to flush the transmission fluid, the timing belt must be a string at this point, and you may have to make other major repairs. Seems like a major case of poor maintenance. Hopefully your troubles stop at the transmission but again, see if you could speak to the seller. Good luck.
SpeedySolara
