SolaraGuy.com • View topic - HID problem
HID problem
HID problem
Postby Ransom8707 » Tue Feb 05, 2008 6:13 pm
I installed the HID (Hi/Low) kit this weekend but it only comes on when high beams is activated. How can i fix this? How can i get my headlights and fogs turned on at the sametime?
The only way I can get the HID kit to work is when I have the high beams activated but theres no way to turn on my fogs and when I switch down to my low beams my headlights turn off and my fogs turn on. :-?
I been searching around for sometime but no luck can anybody help. :-?
Ransom8707
Postby woa_its_j3ff » Tue Feb 05, 2008 6:54 pm
make sure that it is wired up correctly man, there's 3 pins, make sure it's plugged into the right onw.
Postby Ransom8707 » Tue Feb 05, 2008 7:08 pm
I went back and took a look at all the wires made sure the the connectors were securely connected messed around switching the ballasts but no luck :evil:
Ransom8707
Postby facevedo17 » Tue Feb 05, 2008 7:18 pm
even with stock light bulbs if you turn on your high beam the fogs won't work ...only with low beam ...the fix for that is to make your fogs independent there is a write up for that do a search
facevedo17
