SolaraGuy.com • View topic - NOISE
NOISE
NOISE
Postby g00nsquaddd » Thu Feb 07, 2008 2:46 pm
i have a 99' solara and...
here's the noise i always here every time i hit bumpy roads.
it sounds like there's a loose bolt or something inside
somewhere around the front right bumper area.
because when i test drive this other solara before i bought this one,
it made the same exact noise.
i was wondering if any of you guys had encounter this problem.
if so, help? thanks.
g00nsquaddd
Postby unbalancedwood » Thu Feb 07, 2008 3:08 pm
Strut mount bolt...
pop your hood
locate the strut mounts (strut bar connects both sides)
tighten that big nut, 19mm a little tighter...
unbalancedwood
Postby Solorange » Thu Feb 07, 2008 4:42 pm
It could be the front strut mount bearings. From 97 to 99 they had a bad design that was solved in the 2000 and on models. If thats the problem make sure you get the 2000 and up part. My car had this problem.
Postby woa_its_j3ff » Thu Feb 07, 2008 5:03 pm
unbalancedwood wrote:Strut mount bolt...
pop your hood
+1 I doubt it can be anything else.
Back when I had my car's suspension stock my strut mounts made my car make a thunk sound as if there was a giant brick hittin my car every time. Make sure you tighten and in my opinion torque it down a bit to the proper settings. let us know man.
Postby prsolara » Thu Feb 07, 2008 5:27 pm
i also have the exact noise in my lara, but mine is like in the back, not sure also, because sometimes when i hit a bump sounds also in the front. it could be the strut mount in the front and in the back right? :-?
prsolara
Postby woa_its_j3ff » Thu Feb 07, 2008 5:41 pm
prsolara wrote:i also have the exact noise in my lara, but mine is like in the back, not sure also, because sometimes when i hit a bump sounds also in the front. it could be the strut mount in the front and in the back right? :-?
I'd say it would be man, get it checked out!
Postby campfire9 » Thu Feb 07, 2008 6:45 pm
In my case, I have a 99 Solara and had noise every time I went over a speed bump or pothole. It was the upper strut bushing. They were replaced at 17k and again at 38k. Both under warranty. As has been said a bad design and I still have the noise on the driver side front strut. I will have new bushing put in when I change my struts. Only have 80k now so will be a while.
Everybody I have known who had this problem had to replace the strut bushing to get rid of the noise.
Without ammunition, the USAF would be just another very expensive flying club.
campfire9
Postby SolaraBlue » Thu Feb 07, 2008 6:53 pm
hmmm... i have a clunk kind of noise in the rear of my car... i thought it might be the rsb but now i wonder... how much are the strut mounts to replace?
Postby woa_its_j3ff » Thu Feb 07, 2008 7:24 pm
SolaraBlue wrote:hmmm... i have a clunk kind of noise in the rear of my car... i thought it might be the rsb but now i wonder... how much are the strut mounts to replace?
Same ever since I had rsb put in, my car has been having a thunk sound too. People tell me it's my exhaust since it wobbles over some bumps but even if it WAS normal, i had that checked out, nope everything was fine. strut mounts it cannot be even though I double checked cuz I had them retorque'd about a month ago. I have no idea either, nothing is loose..
Postby SolaraBlue » Thu Feb 07, 2008 7:29 pm
if it is the rsb ill just re-grease the bushings... thatll solve the problem. hopefully thats all it is :)
Postby g00nsquaddd » Thu Feb 07, 2008 10:21 pm
thanks guys. the noise got quiet. went a lil more smoother.
well at least for now.
how does that cause to make the noise though?
g00nsquaddd
Postby hskrsolara » Thu Feb 07, 2008 11:00 pm
if you want to do it the right way, you will need new KYB strut mounts. This is the only way I was able to completely eliminate the sound. I just did it when I put on the tokicos and teins, since you will have to remove your strut and spring to put on a new mount. Mounts are usually $60+ each. Rent a spring compressor from autozone, its a pretty easy fix on the fronts...now the rears are a different story.
hskrsolara
Postby SleeperSolara » Thu Feb 07, 2008 11:45 pm
Yeah my dad 1998 Toyota Camry had the problem on the front passenger strut.
It was the strut mount bearin'....
For my car it had 2 different noises in the back. lol.
1. My TRD RSB poly bushin' need some white lithium grease. [makes a creakin' noise].
2. My poly R/C/A bushin'. [makes a squeakin' noise]. I just have to put some white lithium grease where it meets wit the frame mount.
Postby g00nsquaddd » Thu Feb 14, 2008 3:59 pm
thanks for all the tips guys!
but how would you completely get rid of the problem?
g00nsquaddd
Postby Ruski » Thu Feb 14, 2008 4:16 pm
new strut mounts,you should just get new struts and springs as well. do it right the first time.
