SolaraGuy.com • View topic - have problems with interior lights and cig lighter plug?
Postby stitch0901 » Sat Feb 09, 2008 9:49 am
none of my interior lights or reading lights work neither does the clock and where the shifter is those lights not working either? my cig lighter plug doesnt work either? any suggestion other than checking the fuses ? thanks in advanced
stitch0901
Postby lilm » Sat Feb 09, 2008 10:58 am
lol your first step is of course check the fuses.....
have you done anything to your car in the last couple days?
lilm
Re: have problems with interior lights and cig lighter plug?
Postby woa_its_j3ff » Sat Feb 09, 2008 11:07 am
stitch0901 wrote:none of my interior lights or reading lights work neither does the clock and where the shifter is those lights not working either? my cig lighter plug doesnt work either? any suggestion other than checking the fuses ? thanks in advanced
It's def the fuse.
The fuse is located right inside/behind the coinholder to the left of your steering wheel below the air vent.
It's the one that says "gauge" or "acc" i forget. I remembered I stupidly popped my fuse to that when wiring up my gauges.
