SolaraGuy.com • View topic - Toyota's new engines....
Postby richcali1@email.com » Fri May 23, 2003 7:37 pm
New engine lines for Toyota can be found at:
http://www.toyota.co.jp/IRweb/corp_info ... /0225.html
Supra will be available in two trims:
1) 3.5L V6 - 280 HP, 245 Lb-ft Torque Price Range~ 30-32k base - Nissan Z, Mazda RX Competitor
2) 5.2L V8 - 350-360 HP, 375+ Lb-ft Torque Price Range~ 40-45k base - Corvette Competitor
(www.caranddriver.com forum)
Do you guys think Solara will be included in the new engine lines?
richcali1@email.com
Postby Yanks0114 » Fri May 23, 2003 8:48 pm
As of now I doubt there are any plans to put those engines in the solara. The 3mz will suit the solara just fine, not to mention those engines are going to be based on a RWD chassis
Postby Jackass-Jeff » Sat May 24, 2003 2:20 am
aha! I told you the jgtc version of the engine had to be released =P of course, it's not as well tuned 0_0
No wonder they took out the 3s-gte from the jgtc... they wanted to see how well the 3uz-fe @ 5.2L could do :D
1GR-FE ftw!
Jackass-Jeff
Postby Flipside909 » Tue May 27, 2003 11:10 am
xravexboix wrote:aha! I told you the jgtc version of the engine had to be released =P of course, it's not as well tuned 0_0
But doesn't JGTC require only 2.0L engines only? Or am I mistaking that with another curcuit.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Jackass-Jeff » Tue May 27, 2003 1:16 pm
Flipside909 wrote:But doesn't JGTC require only 2.0L engines only? Or am I mistaking that with another curcuit.
No... depending on engine displacement, you are allowed to use forced induction or natural aspiration.
In years passed, Toyota has used the 3S-GTE 2.2 L in their Supra in the 500+ HP grouping. This year, they changed to the 3UZ-FE but bored it out to 5.2 L. It is run N/A due to the regulations for large displacement engines. The NSX 3.5L runs N/A and the RB26DETT runs Twin Turbo. Yet the NSX and Supra (prev years and current) have beat the Skyline. But the Skyline did win a higher altitude race... seeing that N/A pretty much chokes... heh. I think the 2.0L engines only maybe be the CART/IRL
1GR-FE ftw!
Jackass-Jeff
