SolaraGuy.com • View topic - are covertible and coupe seats different
Postby hari-bhari » Sat Feb 16, 2008 8:39 am
will leather seats from a convertible fit into the coupe, front and rear?
hari-bhari
Postby Jackass-Jeff » Sat Feb 16, 2008 9:06 am
The rear is a bench on the convertible. I almost want to say no... but the front should be fine.
1GR-FE ftw!
Jackass-Jeff
Postby hari-bhari » Sat Feb 16, 2008 9:11 am
what do we have in a the coupe? does bench mean its flat all the way across?
hari-bhari
Postby PXLpainter » Sat Feb 16, 2008 9:32 am
Dunno about the Gen 1s, but the Gen 2 convert's have a strap for the seatbelt on the upper corners that I'm not sure would be on the sedan since you have a roof and possibly B pillars that we don't.
Postby NeFaRiOuS_SLE » Wed Feb 20, 2008 2:04 am
Yeah, the rear back seat of the convertible go all the way across instead of a 60/40 split seat, not to mention that the convertible has a different seating configuration; don't remember if there's either no center seat belt or lap-only belt.
Postby PhreakdOut » Wed Feb 20, 2008 5:14 am
I believe the center seat is a little narrower. I know for a fact the Gen 2 rear seat is different. Making the convertible a 4 seater and the coupe a 5 seater.
Postby philosophicaljt » Wed Feb 20, 2008 10:34 am
they are different. I would check to make sure that the wiring is the same, especially for the safety system?
2004 Solara SLE V6
Search
philosophicaljt
