SolaraGuy.com • View topic - Removing center console
Postby Orefus » Sun Feb 17, 2008 3:26 pm
Im trying to figure it out. I dotn want to tear anything. Can anyone walk me through it?
Orefus
Postby Dawgz » Sun Feb 17, 2008 3:34 pm
for the gen 1, remove the ash tray, put ur fingers inside and grab the plastic uptop, pull twards u slowly, the clips should unclip and then u can just shake it off to take the rest off.
Postby bassthrive » Sun Feb 17, 2008 3:53 pm
^ that is spot-on for removal of the dash bezel by your radio / hvac controls. what gen are you? do you have the auto or manual transmission?
by center console, you mean the piece between the driver and passenger's seat?
for a gen 1-1.5 solara with a/t...
pull straight up on the plastic bezel surrounding your shifter
the clips will pop and expose two screws, remove those
open the armrest storage bin in your center console
remove the bottom liner and unscrew two bolts (10mm i think)
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
