SolaraGuy.com • View topic - Hot Engine Starting Problem
Postby Anthony » Sat Mar 01, 2008 6:41 pm
Hey everyone,
I was wondering if anyone can suggest the cause of a hot engine starting problem. When the engine is cold, it starts up no problem. However, when it is hot and I turn the car off for just a few minutes and try to turn it back on, there is some hesitation starting and then when it starts, the RPMs are very low. I either need to turn the car off and then restart (at which point it is OK) or I need to hit the gas peddle to get the RPMs higher and then it is OK. Any ideas? I have about 180,000 km at this point. Any help would be appreciated.
Anthony
2002 SLE V6
Anthony
Postby Midias » Sat Mar 01, 2008 6:58 pm
When was the last time you gave the throttlebody or IAC a good cleaning?
When was your last tune up?
Postby bronzemaxell » Sat Mar 01, 2008 7:07 pm
if it is temperature related, my best guess is the Engine Coolant Temperature Sensor malfunction.
bronzemaxell
