SolaraGuy.com • View topic - Cabin Wind Noise
Cabin Wind Noise
Cabin Wind Noise
Postby Orefus » Fri Mar 07, 2008 3:31 pm
What can i do to elimate it. Whenever i hit high speeds i can hear it and its pretty annoying. Im talking speeds around 60, and the seals around the windoes seem fine.
Orefus
Postby Ransom8707 » Fri Mar 07, 2008 5:12 pm
have you tried or tought of puttin dynamat or fatmat on the whole interior? i heard alot of positive feedback after the install...just personal opinion
http://www.dynamat.com/products_automot ... treme.html
Ransom8707
Postby Orefus » Fri Mar 07, 2008 5:17 pm
i think i have gaps, or areas where air gets into the car. Its quite annoying.
Orefus
Postby Donnie » Fri Mar 07, 2008 5:39 pm
My window seals seem fine too but when I go to a drive through car wash there's one spot on the drivers door where water barely gets in. The seal is just starting to harden and curl in. I bet wind is a lot worse. A Quick Fix It Cure - Turn Up Da Tunes!
Donnie
Postby woa_its_j3ff » Fri Mar 07, 2008 8:08 pm
I had this problem .. no one posted up here too, but no one said anything about it.. must be unknown lol...
Postby Jeffrey Olson » Sat Mar 08, 2008 12:37 am
I get wind noise at the drivers window when the wind blows from passenger to driver side. I can put my hand up and feel the window pane move in and out - some sort of pressure develops. It doesn't happen when the wind blows driver to passenger side.
Maybe I'm hijacking the thread, but I"m wondering about this - what to do...
Jeffrey Olson
Postby tito53 » Sat Mar 08, 2008 12:43 am
yea i get wind noise at about 125mph what can i do?
tito53
Postby woa_its_j3ff » Sat Mar 08, 2008 7:52 am
stick your head out the sunroof and create drag. with your mouth open too.
Postby campfire9 » Sat Mar 08, 2008 10:20 am
I have said this before that using CRC Heavy Duty Silicone spray on the rubber really helps. Just clean the rubber and hold a towel or rag behind the area you are spraying and spray all the rubber. It will soften the rubber and help make a better seal.
I have used this for years and it does help. Also it helps keep the rubber from hardening and cracking.
Try it you will like it. Mickie likes it.
Without ammunition, the USAF would be just another very expensive flying club.
campfire9
Postby Donnie » Sat Mar 08, 2008 1:31 pm
Campfire wrote: "The three best things in life are a good landing, a good orgasm, and a good bowel movement. The night carrier landing is one of the few opportunities in life where you get to experience all three at the same time." That's too funny. I grew around Ft. Campbell. I know guys like you.....LOL Thanks for your service.
Donnie
