SolaraGuy.com • View topic - Reverse making noise
Postby Grnarowana » Tue Mar 11, 2008 9:18 am
It's a 1999 Toyota Solara v6 manual with 123,XXX
Recently I've been hearing a click noise when I go in reverse, and it's not the clank sound when you hit the reverse. The time lapse is about every 3 seconds and it'll go "click" as the car moves in reverse. it'll get louder as I let the clutch go higher. The noise seems like it's coming from the rear. It won't make the noise if I don't move, obviously.
Anybody have this problem?
Grnarowana
Postby woa_its_j3ff » Tue Mar 11, 2008 9:32 am
have you checked the clutch cable? is something lose or overtight/not tight enough?
Postby Midias » Tue Mar 11, 2008 9:36 am
woa_its_j3ff wrote:have you checked the clutch cable? is something lose or overtight/not tight enough?
We have a hydraulic clutch not cable.
Postby Grnarowana » Tue Mar 11, 2008 9:37 am
I'm not quite the mechanic, but the clutch was replaced at least 1.5 years ago and it never made the noise. I start noticing it about 2 weeks ago.
I thought it could have been the bushings or something.
Grnarowana
