SolaraGuy.com • View topic - Getting Best 0-60 Times With An Automatic Transmission
Postby Anthony » Thu May 29, 2003 5:26 pm
I've been wondering how car reviewers get the best 0-60 times on an automatic transmission. I mean, on a standard transmission, the driver would aim to time his/her shifts at the most optimal point. How about on an automatic? With my automatic, I find that the response is different depending on how I start off. Simply mashing the gas pedal from a complete stop is sometimes less effective than letting the car roll so a split second or two and then hitting the gas. Any thoughts on this?
Anthony
2002 Solara SLE
Anthony
Postby Jackass-Jeff » Thu May 29, 2003 5:32 pm
There was an article on www.nissantalk.com/forum on how to launch autos. THe only real thing you can do is get a good launch, but Solaras have a lot of wheel spin =\ That post was taken from a Honda forum... you know... you can launch at 4000 rpms and still not spin the wheels... haha honda and torque =x
I would think that you'd want to step on it like half way or something when you launch then when you know you have the traction, floor that puppy
1GR-FE ftw!
Jackass-Jeff
Postby NASTY » Thu May 29, 2003 8:58 pm
well first youll want to make sure traction control is off
also, i think shifting manually (using L, 2, etc) helps, so you can bring it up to about 6200 before shifting
and whatever that things called where you give the car gas (in gear) while holding the brake, then letting the brakes go
'01 SLE V6
NASTY
Postby Hsakuragi » Thu May 29, 2003 9:58 pm
ouch, that's gonna hurt the engine and the transmission real bad.. :onfire:
Hsakuragi
Postby Jackass-Jeff » Thu May 29, 2003 10:08 pm
hsakuragi wrote:ouch, that's gonna hurt the engine and the transmission real bad.. :onfire:
Agreed.
"holding the break w/ gas" = Torque launch... the tranny can only handle so much =x.
1GR-FE ftw!
Jackass-Jeff
Postby Anthony » Fri May 30, 2003 8:23 am
xravexboix wrote:There was an article on www.nissantalk.com/forum on how to launch autos. THe only real thing you can do is get a good launch, but Solaras have a lot of wheel spin =\ That post was taken from a Honda forum... you know... you can launch at 4000 rpms and still not spin the wheels... haha honda and torque =x
I think this makes sense. I don't think that professional car reviewers would either shift gears (D,3,2,1) or press the gas and brake to obtain the best 0-60 times.
Are there any official 0-60 times for stock 2002 Solara's out there? I've seen some sites simply state that 0-60 is in the low 7 seconds.
Anthony
2002 Solara SLE
Anthony
Postby Stock Solara SEV6 » Fri May 30, 2003 2:19 pm
I don't have an automatic, but based on past experience you should be able to brake torque to 1500 - 2000 rpm, then mash the throttle and release the brake at the same time. Tailor the starting RPM to minimize spinning. The transmission will be OK as long as you don't brake torque it for more than a few seconds and allow time for the torque converter to cool back down before repeating.
Stock Solara SEV6
Postby bkp_duke » Sat May 31, 2003 7:27 am
along the same lines - if you are going to torque launch a lot, i would recommend you move over to a synthetic ATF like Mobile One. It will help keep the tranny and particularly the torque converter cooler and reduce the potential for damage
bkp_duke
Postby Flipside909 » Sun Jun 01, 2003 10:13 am
bkp_duke wrote:along the same lines - if you are going to torque launch a lot, i would recommend you move over to a synthetic ATF like Mobile One. It will help keep the tranny and particularly the torque converter cooler and reduce the potential for damage
You can do that, but torque braking only kills your engine mounts...using synthetic or not for your ATF will not stop that extra stress to other components.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby NASTY » Sun Jun 01, 2003 2:08 pm
Flipside909 wrote:You can do that, but torque braking only kills your engine mounts...
flip (or anyone who knows), can you give a brief explanation why? that just doesnt makes sense to me...
'01 SLE V6
NASTY
Postby Flipside909 » Tue Jun 03, 2003 11:22 am
Because when you're holding the brakes...and you have the tranny in drive...and pressing the gas, you're trying to push the engine to push the tranny..to push the wheels to get moving. But since you have the brakes pushed down, the power has to be exerted somewhere...so the engine and tranny will take the brunt of the stress since that force has to go somewhere. If you've never noticed, your engine kinda rocks back and forth when you start the car, when you rev it up and while you shift gears auto or manual.
www.clublexus.com
Flipside909
