SolaraGuy.com • View topic - Manual Transmission problems
Postby alltrac92 » Wed Mar 12, 2008 7:00 pm
I have a 2000 V6 5-speed and 1st gear is near impossible to engage when downshifting from second to first around 5 mph. It will make a grinding sound but it does not sound like the transmission but more from the shifter area. First gear will engage easy at a dead stop. Also in the morning when the car is cold first to second is hard after it warms up no problems.
I changed the gear oil to Royal Purple and it did not fix the problem. Is there a better gear oil for this issue? or some adjustment? I did notice the clutch pedal has worn a spot on the factory floormat so I wonder if the clutch is not fully engaged? but all other gears are fine.
alltrac92
Postby ThatVietGuy » Wed Mar 12, 2008 7:18 pm
Probably the sychros.
My friend's 240SX does the EXACT same thing.
ThatVietGuy
trans
Postby NRDriver » Wed Mar 12, 2008 7:19 pm
yup
NRDriver
Postby Eye8Pussies » Wed Mar 12, 2008 10:12 pm
there is no first gear synchro....that is to prevent you from dropping into 1st while cruising by accident and blowing your tranny. better to grind the gears than to engage them at high speeds
you shouldn't have the problem getting into second gear though
Postby (K) » Thu Mar 13, 2008 1:05 am
Has your girlfriend or significant other been driving your car?
(K)
Postby alltrac92 » Thu Mar 13, 2008 6:35 am
(K) wrote:Has your girlfriend or significant other been driving your car?
Nope, I just bought it like that. Would a worn synchronizer be more noticeable when the car is cold versus after a few miles of driving? Because after the car warms up the transmission is fine. Maybe I should try the GM synchromesh. Do you guys run full synchromesh or mix it with gear oil?
alltrac92
Postby Midias » Thu Mar 13, 2008 7:13 am
I am not sure anyone here uses the GM stuff. Most use straight gear oil usually royal purple or Mobil 1.
Postby (K) » Thu Mar 13, 2008 9:07 am
When you say "from 5 mph" do you mean from 5 mph as in from hard braking or from coasting speed?
Give the gas pedal a slight goose before you downshift to first. A VERY slight goose.
Also how many miles did the transmission have before you did the gear oil change? If it had high mileage, changing the oil might actually have done more harm than good.
(K)
Postby Eye8Pussies » Thu Mar 13, 2008 12:20 pm
if you think that the synchromesh might help, give it a try for sure....I know a couple of camry owners that have tried it with good result
same as pretty much any manual transmission driver who has tried it
Postby Ruski » Thu Mar 13, 2008 12:32 pm
synchromesh might help, i know a couple people that have used it in their cars, alot of integra guys use it , in there R's . give it a try
Postby Solorange » Thu Mar 13, 2008 5:17 pm
I wouldn't recommend using a GM Syncro. My 2nd gear syncro went bad in my camaro I had.
Postby akora12 » Thu Mar 13, 2008 5:29 pm
Eye8Pussies wrote:there is no first gear synchro....that is to prevent you from dropping into 1st while cruising by accident and blowing your tranny. better to grind the gears than to engage them at high speeds
correct.
Postby Ivanhoe » Sat Mar 22, 2008 11:11 pm
+1 on the syncro thing....your tranny is fine, nothing to worry about.........
but if you want to improve the overall feel, try.............
Redline MT-90!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Made my tranny shift like new. I used to get a slight grind every once in a while when shifting too quick.....and after reading a thread on here, I swapped in Redline MT-90 and never had the problem again no matter how quick I shifted! Also it made cold shifts much smoother!
Ivanhoe
Postby mazen222 » Tue Mar 25, 2008 7:52 am
i heared you hould never downshift to first gear while the car is moving... i have the same problem when the car is cold and im shifting from 1 to 2
i'll try redline mt90, thx ivan
1999, 5 Speed V6
mazen222
Postby Jai_Jai_Binks » Tue Mar 25, 2008 5:17 pm
mazen222 wrote:i heared you hould never downshift to first gear while the car is moving
I guess you and I are the only one's that still do that! I'm suprised that some of you downshift to one! Amazing... :roll: Downshifting to 2 or 3 or 4 i can understand. But to first gear...sorry...for the :agrue:
