SolaraGuy.com • View topic - replaced tranny...now BADD gas milage??
Postby azngurlNxtc » Thu Mar 13, 2008 4:02 pm
okay so i have a 2001 solara Automatic 4-cyl
18.5 gal tank
has about 107,000 miles on it
tranny replaced at 105,000
when i bought the car the transmission f**ked up on me and i had to replace it. i took it to the mechanic and they replaced it when a 2000 camry transmission and it ran fine. until i noticed that a FULL tank of gas gave me barely 200 miles. i was veryyyy mad, considering gas prices these days. so i used some of that solution to clean your injectors and the next tank went back up to about 300 to the gallon but thats still VERY low. i think im supposed to get about 450-500miles per tank.
soo any ideas why this is happening? ive been losing so much money on gas the past month. been using the fuel system cleaners but its not helping at all now its back down to 200/tank.
could it be the tranny?
pleeasee some one help me
azngurlNxtc
Postby kingkakyle » Thu Mar 13, 2008 7:07 pm
what were u getting before ur tranny went bad
i have a 05 4cyl....same engine and i can get around 270-330 per tank
its partially because of all the la traffic and parking at school i probably sit idle about half the time my car is on....
so if u do a lot of traffic dricing and such 300 to a tank isn't so bad
now i dunno y u only get 200 now... but the 300 doesn't mean tehres a problem
Postby azngurlNxtc » Thu Mar 13, 2008 8:46 pm
i was getting really good mileage when i first bought it
like 25-30mpg
but now its like 12mpg
i dont idle my car at all and half of it is freeway driving
i dont think it should be that low though
azngurlNxtc
Postby Jakecallun20 » Thu Mar 13, 2008 8:51 pm
Just to add, you guys don't have the same engines. 05 4cyl is 2AZ 2.4 and the 01 4cyl is the 5SFE 2.2L
Postby rewmomi » Thu Mar 13, 2008 9:31 pm
I dont know I just replace my tranny last weak cuz int FV(Ked up on me too but i got the opposite result. it gave me more gas milage. try to get ur fuel system cleaned with b&g products, and get you carberator cleaned as well that helps?
rewmomi
Postby hskrsolara » Thu Mar 13, 2008 10:15 pm
rewmomi wrote:I dont know I just replace my tranny last weak cuz int FV(Ked up on me too but i got the opposite result. it gave me more gas milage. try to get ur fuel system cleaned with b&g products, and get you carberator cleaned as well that helps?
please don't clean your carburetor...well, if you do, good luck finding it...
honestly, take it back to the guys that installed it and tell them. I have never heard this before. maybe you have a gas leak? or a fuel line/filter thats damaged? have you noticed any spots on the pavement lately?
I had the 5sfe in my old camry and rarely got over 21 mpg...they really aren't expected to get 500 miles per tank.
hskrsolara
Postby azngurlNxtc » Sun Mar 16, 2008 10:40 pm
ive been using the fuel injector cleaners in my gas everytime i pump but it doenst seem to be doing anything
so i guess im gonna check the spark plugs, n change my oil..
n a few other things
then if that doenst work guess imma take it to the shop
thanks guys!
let know if u have any other suggestions
azngurlNxtc
Postby kingkakyle » Sun Mar 16, 2008 11:51 pm
Jakecallun20 wrote:Just to add, you guys don't have the same engines. 05 4cyl is 2AZ 2.4 and the 01 4cyl is the 5SFE 2.2L
thanks haha i always thought it was changed in 01......guess it was 02+
