SolaraGuy.com • View topic - Aiming headlights side-to-side
Postby Gangis » Fri Mar 14, 2008 9:37 pm
Is it possible for us to re-aim our headlights sideways? Aiming it up and down is pretty easy, but how about left and right? Does anyone have pics and/or detailed instructions? Thank you!
Gangis
Postby PXLpainter » Fri Mar 14, 2008 9:43 pm
Be careful cuz they may stay that way! :lol:
Postby ThatVietGuy » Fri Mar 14, 2008 9:44 pm
You can change it side to side, but the screw is in a pretty tight spot.
If you search you should be able to find an answer.
ThatVietGuy
Postby Gangis » Fri Mar 14, 2008 9:45 pm
LMAO!!!
Gangis
Postby Gangis » Fri Mar 14, 2008 9:47 pm
ThatVietGuy wrote:You can change it side to side, but the screw is in a pretty tight spot.
Thanks. I did search but I couldn't find the information. I might've used the wrong search keywords, though...
Gangis
Postby ThatVietGuy » Fri Mar 14, 2008 11:52 pm
I found plenty searching "headlight adjustment," but the one picture that tells you where the knobs are is down.
But the knob for the side-to-side adjustment is located under a grey rubber cap (at least I think it is grey).
ThatVietGuy
Postby Gangis » Sat Mar 15, 2008 8:47 am
Thanks! Got it!
Gangis
Postby Solorange » Mon Mar 17, 2008 5:48 pm
If you bought black housing lights good luck. I couldn't adjust mind from left to right. Up and down worked ok up to an extent.
Postby akora12 » Mon Mar 17, 2008 6:32 pm
The left to right adjustment shouldn't need adjusted unless you've had the reflector removed from the housing. The only exception would be aftermarket headlights.
