SolaraGuy.com • View topic - Need Help, Code: P0135
Postby Americanctm10 » Mon Mar 17, 2008 3:19 pm
On my way back from school today check engine light came on. Got it checked at Autozone.
Code: P0135
Something wrong with 02 sensor. (bank 1, sensor 1)
Anybody have this 02 sensor problem? Called the dealership just to see what they would say, and they said its probably gonna cost $350 plus.
Anybody got anymore info on this, any help is appreciated.
Thanks.
Americanctm10
Postby Dawgz » Mon Mar 17, 2008 3:50 pm
350!?
if ur cali spec, thats a A/F sensor.
That should cost u no more than 230$ from toyota.
If ur Federal spec, thats a o2 sensor, which is like 60 bux....
Postby Americanctm10 » Mon Mar 17, 2008 6:27 pm
Ya its reading as an 02 sensor failure. Might be 60 bucks, but they count labor costs too.
Americanctm10
Postby Brettboy » Mon Mar 17, 2008 7:17 pm
Here ya' go. I've done this as well. It actually isn't too difficult. You can do it!
http://www.solaraguy.com/viewtopic.php?t=38603
99' SE V6 Black Metallic
Customized grille, 18 inch ADR rims, Injen intake, K&N Filter, 20% tint, Iggee custom seat covers, teins, tokicos
Brettboy
Postby r0yalty » Wed Mar 26, 2008 8:08 am
Brettboy, thanks for that advice, i need to do my 02 sensors as well. did you buy them at an autozone, or do you have to get them from the dealer?
r0yalty
Postby Brettboy » Wed Mar 26, 2008 8:32 am
I bought it from autozone. It was about 100 bucks. Make sure you get one with the clip already attached so you don't have to do any splicing.
Brettboy
Postby Brettboy » Wed Mar 26, 2008 8:43 am
Here is the exact one I bought. It is federal specific for a 6 cylinder.
http://www.autozone.com/selectedZip,370 ... ectZip.htm
Brettboy
Postby Chinky420 » Wed Mar 26, 2008 9:23 am
i've had that code up for about 6 months now. if you neglect to change it, you will be running richer than normal.
brettboy - how long ago did you change yours? i have heard that some lara's had problems with bosch sensors after so many miles. also, did your code pop up after you installed your injen, or was it more of a random occurance?
Chinky420
Postby Brettboy » Wed Mar 26, 2008 10:22 am
I changed it about 4-5 months ago. The bosch worked just fine. I have 167,000 miles on my car and the code went off after I cleaned my throttle body.
Brettboy
