SolaraGuy.com • View topic - 99 Solara V6 cruise control-- not working--can't find fuse..
Postby synenergy52 » Tue Mar 18, 2008 2:59 pm
I press the button but no light lights up on the dashboard. I even tried "setting" the cruise control just in case it was the bulb in the dash that burnt out--no luck. Is there a fuse for the cruise control? Where should I look? The cruise control actuator under the hood appears fine.
MY06 E46 BMW 325ci 5MT, Sport Package, Active Xenon, body colored front reflectors.
MY99 Solara SLE V6 4AT (all the SLE junk)
synenergy52
Postby campfire9 » Wed Mar 19, 2008 6:18 pm
Check the instrument panel fuse location behind the coin/etc pull down door to the left of the steering wheel. Its fuse #27. If it is bad then you probably didn't have brake lights, ABS, and a few other things. Anyway that's the fuse # and location. Good luck.
Without ammunition, the USAF would be just another very expensive flying club.
campfire9
Postby synenergy52 » Thu Mar 20, 2008 12:25 pm
All my stuff works perfectly so it can't be that. Thanks for the response though (I"ll check the fuse anyway) Anybody else?
synenergy52
synenergy52
