Blinkers
Does anyone know how to speed up the blinkers/turn signals?
SpeedySolara - SolaraGuy Street Racer
SolaraBlue wrote:upgrade the blinker fluid. the oem blinker fluid is weak compared to some of the stuff you can get aftermarket.
Donnie wrote:SolaraBlue wrote:upgrade the blinker fluid. the oem blinker fluid is weak compared to some of the stuff you can get aftermarket.
What? Huh? No That's just not rig.....Whaaaaat? I know that while I played around in my younger years I let a lot of technology pass me by but "Blinker Fluid" Say it aint so Blue, Say it aint so. OK explain in 20 words or less, What is blinker fluid? Or did I just fall into a world wide on the internet joke right here in front of God and everybody?
SolaraBlue wrote:"Are you blinkers sluggish? Do they make an annoying ticking noise? Do they not flash fast enough? Here's your solution. Little do people know, factory quality blinker fluid should be changed every 150,000 blinks. Our blinker fluid lasts ten times that. KaleCoAuto high quality synthetic blinker fluid meets the highest DOT standards while not being in the least bit DOT legal! KaleCoAuto blinker fluid provides you with thousands of hours of reliable blinking without the wear and tear on the flash-synchro's that the other blinker fluids cause. KaleCoAuto blinker fluid will not lose its viscosity even in the most extreme situations. Why buy that old dino-blinker fluid, when you can get our unique patented synthetic formula? Satisfaction guaranteed!! For use in any car."
heres how to change it:
http://www.geocities.com/changeyourblin ... luid1.html
heres where to buy it, its only $8.99 too:
http://kalecoauto.com/index.php?main_pa ... ducts_id=6
Jakecallun20 wrote:SolaraBlue wrote:"Are you blinkers sluggish? Do they make an annoying ticking noise? Do they not flash fast enough? Here's your solution. Little do people know, factory quality blinker fluid should be changed every 150,000 blinks. Our blinker fluid lasts ten times that. KaleCoAuto high quality synthetic blinker fluid meets the highest DOT standards while not being in the least bit DOT legal! KaleCoAuto blinker fluid provides you with thousands of hours of reliable blinking without the wear and tear on the flash-synchro's that the other blinker fluids cause. KaleCoAuto blinker fluid will not lose its viscosity even in the most extreme situations. Why buy that old dino-blinker fluid, when you can get our unique patented synthetic formula? Satisfaction guaranteed!! For use in any car."
Blue, dude. No need for that. He asked a simple question. Doesn't make him a "ricer". Chill.
Toy1mzfe wrote:they have relay boxes that make the flick quicker like 12x or something
