SolaraGuy.com • View topic - window squeak
window squeak
window squeak
Postby bassthrive » Sun Mar 30, 2008 10:31 am
How do I fix a noisy driver's side window? It squeaks when I roll it down. The rubber seal is in good condition from what I can see. Is there a second rubber seal further down in the door that could be causing the problem (seems like the sound is coming from there).
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby kwyse » Sun Mar 30, 2008 2:18 pm
I've had the same issue since its gotten cold out. I tried spraying silicone lube down the crack the window slides into, which worked well until it got cold again. Ill retry this in a couple weeks when it gets warmer. My rubber seal is also in pretty good condition.
kwyse
Postby NeFaRiOuS_SLE » Sun Mar 30, 2008 3:29 pm
Is there any additional sounds? Might be the window guide being crooked, but to hit the issue square on I suggest disassembling the door panel and lubricating it (to further expand on kwyse's post).
