SolaraGuy.com • View topic - Smoke from the engine?
Postby 99V6solaraSE » Mon Mar 31, 2008 11:59 am
I see smoke coming from this location. I dunno what it could be. Just a guess but a rear header leak?
you can see the smoke in this pic ^^
99V6solaraSE
Postby rollaevo99 » Mon Mar 31, 2008 12:17 pm
or may be you have an oil leak..... and it hits that part..... it happens with my old camry....... try to rinse it off with oil cleaner & water.....see what happens
Postby Sebas007 » Mon Mar 31, 2008 12:31 pm
+1
Postby CamryOnBronze » Mon Mar 31, 2008 12:39 pm
yep, agreed... a lot of oil leaks can leak onto the y-pipe, thats what mine is doing right now haha...
Re: Smoke from the engine?
Postby Gregtrd » Mon Mar 31, 2008 2:49 pm
99V6solaraSE wrote:I see smoke coming from this location. I dunno what it could be. Just a guess but a rear header leak?
looks like you need to check your valve cover gasket.
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Postby Solorange » Mon Mar 31, 2008 4:22 pm
Exactly check your valve cover gasket. Oil is probably running down the side of your block burning on your exhaust manifold.
