SolaraGuy.com • View topic - gotta oil question!!!
Postby shocar4 » Sat Apr 12, 2008 6:10 pm
what is the contraption or port that is located to the right of the oil filter on the 1mz motor! i am installing my oil pressure gauge and i am going to get a sandwhich adapter, but i noticed this object that has a drain port beneath it like if you loosened the bolt it would drain oil! anyone know what this is for! almost looks like my pressure sensor would thread into it, but i am sure that there is a purpose for it! thanks
shocar4
Postby SleeperSolara » Sat Apr 12, 2008 6:28 pm
If you had a picture that would help??
But if i'm correct that little port that looks like a goldish color is for the radiator drain for the front of the engine.
There's 3 places to drain the radiator fluid, one on the radiator, and 1 on the front of the engine block that has a goldish look to it, and then there's another one on the rear of the engine block.
The front port is for drainin' the front of the block and rear port is for the rear of course.
If you loosen the front one be sure to tighten it back as much as you can, i loosened it once to change my radiator fluid and didn't tighten it back up all the way it was drippin' radiator fluid until i fully tightened.
Postby shocar4 » Sat Apr 12, 2008 6:41 pm
thanks man...that makes total sense!!!
shocar4
Postby Jakecallun20 » Sat Apr 12, 2008 8:25 pm
shocar, if you could write up a small tutorial for installing an oil pressure gauge, that would rock! I am going to put one in, just have no clue where to begin. 8)
Postby shocar4 » Sun Apr 13, 2008 6:32 pm
i got all my gauges installed except i need to get a sandwich oil pressure adapter! trying to find out which one i need! all of the wires are ran just waiting on ordering the adapter! i will take pics soon!
shocar4
Postby Eye8Pussies » Sun Apr 13, 2008 7:43 pm
pretty much any sandwich adapter will work
off hand- greddy makes one, and so does transdapt
Postby shocar4 » Sun Apr 13, 2008 7:48 pm
^^^yeah greddy is probably the one that i am going to go with!
shocar4
