SolaraGuy.com • View topic - small vibration under clutch pedall help please
Postby *solara2000* » Thu Apr 17, 2008 5:51 pm
okay well as i mentioned couple weeks ago, i had my car done at this shop which f**ed it up. and there was a big vibration under the clutch pedal.
well i took the car to a different shop, and they fixed it. the problem was that when those idiots installed the fly wheel one of the bolts brok which caused all that vibration. it slightly burned the flywheel because of that.
and now after i got it fixed again, there is still verry little vibration, but not as it was>
any ideas?? please let me know. i have stage II spec clutch and fidenza flywheel.
2000 Solara supercharged!!!!!!!!!!!!!!!
*solara2000*
Postby Eye8Pussies » Thu Apr 17, 2008 7:00 pm
are both the flywheel and the clutch brand new?
Postby *solara2000* » Fri Apr 18, 2008 9:04 am
Eye8Pussies wrote:are both the flywheel and the clutch brand new?
yes.
*solara2000*
Postby Eye8Pussies » Fri Apr 18, 2008 3:57 pm
then it may just be the flywheel and clutch settling in...if it's still there after the break in period, then check up on it again...
Postby *solara2000* » Fri Apr 18, 2008 11:38 pm
Eye8Pussies wrote:then it may just be the flywheel and clutch settling in...if it's still there after the break in period, then check up on it again...
okay thanks
*solara2000*
