SolaraGuy.com • View topic - charcoal canister install
Postby rewmomi » Sun Apr 20, 2008 1:02 pm
Hey I just got a charcoal canister from an sg member and he told me to get the diy book............. forgot what its called but it was about 50 bucks to purchase and i dont have that right now being a college student and all. So if anyone can help me by telling me how to do it, or photo copying the instructions, or had a diy , please help thanks SG :D
rewmomi
Postby bronzemaxell » Sun Apr 20, 2008 4:16 pm
i did installed charcoal canister on a 99v6, i did not use any diy book, all i did was jack up the rear with two jack stands, use a 14mm 1/2" socket with a swing head adaptor, disconnect all hoses and wires, and there was enough from to slide the whole charcoal canister from the passenger side rear.
bronzemaxell
Postby Solorange » Sun Apr 20, 2008 6:58 pm
Rewmomi, I will scan the pages for you at work tomorrow. I can't believe you can only find the book for $50 bucks. I bought it at autozone for $20.
Postby rewmomi » Mon Apr 21, 2008 8:39 am
they dont have it bro^ :(
rewmomi
Postby rewmomi » Mon Apr 21, 2008 8:41 am
bronzemaxell wrote:i did installed charcoal canister on a 99v6, i did not use any diy book, all i did was jack up the rear with two jack stands, use a 14mm 1/2" socket with a swing head adaptor, disconnect all hoses and wires, and there was enough from to slide the whole charcoal canister from the passenger side rear.
Seems easy enough but when i took it to my mechanic he told me i needed to take the cross member out and jack it and replace the unit there after? but thanx i just need to buy some stands i heard theyy got a sale at autozone fro them lol
rewmomi
Postby Solorange » Mon Apr 21, 2008 3:28 pm
There may be enough room to wiggle in and out without taking the cross member off. Check your email.
Postby bronzemaxell » Tue Apr 22, 2008 6:17 am
mine was a solara 99 V6, as soon as you put the car on jack, the rear control arm drops a bit along with the wheels, giving enough room to slide the charcoal canister out from the passenger side rear, it is held by 2 of 14mm bolt, use 1/2" socket with swing head adaptor and a 8" or 12" extension, some sort of eye shields, label where each hoses and wire goes for re-installation, i am telling u because i did it myself that way for P0441 and P0446 error without touching the any rear control arm. took me a little over an hour, and i had a back pain next day. but i no longer have the CEL.
my guess is if the shop were to do it, the put it on lift, and once they remove the control arms, they will have plenty of room, but i rather not touch those control arm myself, i believe they are also for alignment, if you take them off, probably need to check alignment awell, another $60 at least .
bronzemaxell
Postby Solorange » Tue Apr 22, 2008 3:58 pm
^^There isn't a control arm on the rear. There are tie rods in the rear which I think your referring too. You can probably just drop the rear cross member which the exhaust and those tie rods may interfere with the complete removal, but with it loose you may be able to maneuver it in such a way that allows enough room for you to slide the charcoal canister out.
Postby bronzemaxell » Tue Apr 22, 2008 8:07 pm
i dont' know much about the tie rod, and the only tie rod i know about is the one in front wheel for steering.
i bought one of those rod, toyota named them lower control arm no.2 for around $100 each, due to bad bushing. and that one is for alignment purpose.
here is a link, they also called them control arm
http://www.autopartswarehouse.com/details/QQToyotaQQSolaraQQOE_ServiceQQControl_ArmQQ19992003QQW0133-1607084.html
oh, and i forgot to mention, my oem muffler and exhaust pipe is not really on the way when i removed and reinstalled the charcoal canister.
bronzemaxell
Postby Solorange » Wed Apr 23, 2008 3:22 pm
Thats weird. I must have missed it. I looked under the car and I just see two rods connecting to the rear hub.
Postby rewmomi » Tue Nov 18, 2008 12:01 pm
Hey sorry to bring this up again but is their a filter I need to replace when I al doing this charcoal canister swap?
rewmomi
Postby System_Crash » Tue Nov 18, 2008 3:14 pm
The "charcoal canister" is the "filter" for emission gasses from the fuel system. It filters the air so no harmful gasses exit the vehicle. So in short no, you are changing the filter.
Pearl White 2004 Solara V6 90,000 miles
System_Crash
Postby that1mexguy » Sat Nov 29, 2008 1:00 pm
hey i just got my charcoal canister and planning to replace it this weekend, anybody took any pics that wouldn't mind sharing? I'm really hoping I don't have to remove the exhaust.. thanks a bunch!
that1mexguy
Postby that1mexguy » Mon Jan 05, 2009 11:39 am
well, to any of you that said changing it was easy... a big F*U!!! LOL man, talk about Pain in the @$$!!! i mean, technically it ain't hard, but just getting my fat @$$ under the car and trying to disconnect the hoses and wires is not as simple as it sounds!! Anyway, I got it done and hopefully the freaking check engine light wont come on anymore.
that1mexguy
Postby SpeedySolara » Wed Jan 07, 2009 9:41 pm
that1mexguy...your car looks nice. You have Tokico struts, right? I have Tokico's on my car and mine sits pretty high but still lower than stock. Do you have the blue ones? I do.
SpeedySolara
