SolaraGuy.com • View topic - Just got a 2000 Solara! have some questions..
Postby The TRD » Fri Apr 25, 2008 12:00 am
everything done
Super Super Solara !
The TRD
Postby ThatVietGuy » Fri Apr 25, 2008 12:12 am
- Shaking is probably a wheel balancing issue.
- 225/50/17 would be closest to the stock size
- 5w-30 synthetic is fine
The other two I really have no idea.
ThatVietGuy
Postby SdeA » Fri Apr 25, 2008 12:22 am
For the grill part you could buy an aftermarket grill (renova). Look way better then stock.
SdeA
Postby Donnie » Fri Apr 25, 2008 4:55 am
And you are?
Had my wheels balanced the other cause of the same shaking in the steering wheel. My guy took one of the weights on the pass front and moved it 1/4". That's all it took.
Donnie
Postby woa_its_j3ff » Fri Apr 25, 2008 5:22 am
before anyone else says it.. just try to search bro. lot of people here hate having to repeat themselves every other day. just .02..
but yeah welcome to solaraguy man!!
Postby NVDIS1 » Fri Apr 25, 2008 6:07 am
welcome to the place to be :D
Postby DrLove » Fri Apr 25, 2008 7:13 am
All the Gen1 Solara has the peeling problem on the emblems/grill.
I bought a new grill last year from the dealer, cost me $200.
Still nice and chrome.
Renova grill is cool, but I didn't want a "racing" look, I prefer the luxuous look like a Lexus than a sport car.
I have also the shaking problem with my summer tires.. I will balance them and use them for another year or go buy some new Falken tires...don't know yet..
Mazda 6 2010 6 speed black GS
DrLove
Postby The TRD » Sat Apr 26, 2008 9:47 pm
:D
The TRD
Postby Eye8Pussies » Sat Apr 26, 2008 9:51 pm
ThatVietGuy wrote:- Shaking is probably a wheel balancing issue.
close but not quite
closest size is 225/45/17 or 215/50/17
Postby Jakecallun20 » Sat Apr 26, 2008 9:59 pm
First of all, welcome!
As your grill problem, that is normal. For me what I did, is sanded the grill down and pulled off the Toyota emblem in the center, then painted it black, to match my car. Painted the logo, put it back on then replaced it on the car. Looks great, goin on 7 months.
I too had the wood issue, Its from the sun and heat baking the trim and making it fall apart basically. I just sanded mine down a bit around the edges and painted it all black. I don't like wood trim so it worked out fine for me.
As for motor oil, I use Castrol Syntec 5w-30 "Fully" synthetic, with a Mobil 1 oil filter. I'm assuming you have a V6.
The wheel shaking and tire questions I don't have an answer for you, sorry.
Re: Just got a 2000 Solara! have some questions..
Postby tweazy » Mon Apr 28, 2008 2:49 pm
Regarding the center console wood trim, Are these the sticker type? The 2000 Solaras did not come with the center console in wood trim. The only wood trim that the Solaras come with are those that goes along the door and around the dash. Nothing in the center console These are aftermarket parts.
Anyway, I have the same issue. I installed a wood trim kit in my center console and the top part of the wood trim is peeling off due to heat. They tend to be flexible when heated and I am planning to just glue them back on. ...though I am not sure which glue to use.
tweazy
Postby Garrryyunit » Mon Apr 28, 2008 4:20 pm
everyone pretty much covered everything that i know. so Welcome!
Photo My Car
2002 Solara SE - Sold
1992 Civic VX - Current
2003 S2000 - Current
Garrryyunit
Postby The TRD » Tue Apr 29, 2008 1:42 pm
tweazy wrote:Regarding the center console wood trim, Are these the sticker type? The 2000 Solaras did not come with the center console in wood trim. The only wood trim that the Solaras come with are those that goes along the door and around the dash. Nothing in the center console These are aftermarket parts.
Its the actual wood trim, like on the side doors and such not a sticker. Ill try to take a picture.
The TRD
Postby LatinUSMC » Tue Apr 29, 2008 2:17 pm
the door trim is one complete plastic piece held in by 4 delicate clips, so be carefull when removing those.theyre hard to find.
just take em off and sand with extra fine sandpaper and repaint them, thecenter console start at the ash tray to remove.
LatinUSMC
