SolaraGuy.com • View topic - Just got a SOLARA Have some question
Postby 4000solara » Tue Apr 29, 2008 12:14 am
-When should I change the timing belt the car has 106,600??
Those accessory belts seem to be in good condition,what are the symtoms?
-The power motor is also dead where i can get a motor.
-The power door is not working either,but i can hear the sound form the relay is in working condition like tic tic sounds.
-The keyless entry is not working either,not sure the remote or the module is not working.
Please help guys.
My email is:
Sf_Plus@yahoo.com
4000solara
Postby Chinky420 » Tue Apr 29, 2008 10:42 am
timing belt should be changed after ~90k i think. i haven't changed mine @ 127K, because i inspected the belt for cracking/wear and it seemed good. also, i had bought my lara used @ 93k miles, so i wasn't sure if it had already been changed or not (hence the visual inspection).
which power motor are you talking about? like the power window motor? if that's the case, check a salvage yard for replacements.
i don't know crap about the power lock system. maybe check out a haynes manual or someone here may have some answers.
as far as the keyless entry is concerned, have you checked if the battery is good? you can open the remote up with a dime, and i think the battery size is 2032. if there's a new battery in it, i believe there's a tutorial on programming the transponder.
dont forget to change the spark plugs, wires, change the oil, and the air filter.
you should go introduce yourself now.
Chinky420
Postby Dawgz » Tue Apr 29, 2008 10:54 am
U cant just look at a timing belt and say its good to go, if the deadline is up for the change and it needs the change, do the change.
A timing belt is not something u can skimp on.
