SolaraGuy.com • View topic - Caliper Rebuild - Pad support plates and Slide pins
Postby tboidsc » Thu May 01, 2008 8:57 pm
I had my calipers powdercoated and purchased all new pad support plate kits for the front and rear. When they came back all the originals supports and pins were removed, and I do not remember which go where. I also wanted to know where the sliding pin with the bushing goes for the Front and Rear. Does it really matter which slot this pin with the bushing goes in, top or bottom?
Does anyone have a detailed blowup of the front and rear brake systems, or maybe just some super closeup photos of their calipers insalled, so that I can get an idea where the pad supports go. They appear to be slightly different from each other.
The Hanyes manual I have isn't clear, and actually appears to be different than my application (maybe 4cyl pics)
In the front, one of the shims has an extra tab on the top with a hole in it, while the other doesn't.
2000 TRD Solara 5-sp DWP
1MZ-FZE engine
Supercharged, lots of extras
Renova front Grille
tboidsc
