SolaraGuy.com • View topic - Is this normal for my headlights and fogs to do this?
Postby BaldEagle » Mon May 12, 2008 5:32 pm
Funny...With my headlights on the fogs are on.
If I turn on the bright lights the fogs go out.
Switch back to dim and the fogs come back on.
Is that normal?
Question 2
I have a 2001 Solara SLE V6 AUTO.
I am assuming its a GEN 1 but dont know the diff between gen 1 and 1.5.
Please clarify.
Question 3
I have H4 BULBS STOCK?
I have read go with sylvania to make a little better light.
What say you?
Thanks guys.
BaldEagle
Re: Is this normal for my headlights and fogs to do this?
Postby JMSinMaryland » Mon May 12, 2008 5:37 pm
BaldEagle wrote:Funny...With my headlights on the fogs are on.
Is that normal?
YES
Question 2
Please clarify.
Gen 1 is 1999-2001
Gen 1.5 is 2002-2003
Question 3
What say you?
Good choice, don't go with the Ultra's just the regular, switch out your fogs as well
Thanks guys.
JMSinMaryland
Postby solarashow » Mon May 12, 2008 6:33 pm
Is that normal?
if you want, you can make the fogs work independently using this tutorial
http://www.solaraguy.com/viewtopic.php?t=9234
solarashow
Postby kwyse » Mon May 12, 2008 6:44 pm
Question 1: Yes this is normal. I'd recommend the independent fog light mod though.
Question 2: Yes. Gen 1 is from 1999-2001. It has the red and white tail lights. Gen 1.5 has the red, white and amber tail lights.
Question 3: I have Sylvania and they're not really that much brighter or whiter. If you want this, you may want HID.
kwyse
Postby redgen1 » Fri May 16, 2008 8:29 am
the only real difference between the 99-01 gen 1 and the 02/03 gen 1.5 are the tails as previously mentioned and the front, the lower lip is a little different and the grille is as well..
02 SLE V6
Kaizen *constant improvement*
redgen1
