SolaraGuy.com • View topic - TPS???
TPS???
TPS???
Postby shocar4 » Thu May 15, 2008 6:22 am
does anyone know which wire on the throttle positioning sensor is the out going wire! the wire that changes current when the throttle is hammered?
shocar4
Postby shocar4 » Thu May 15, 2008 5:04 pm
nobody know?
shocar4
Postby no_escape » Thu May 15, 2008 5:18 pm
no_escape
Postby corlon » Thu May 15, 2008 5:19 pm
for a 99 sle v6 you should have a yel, blu and brn wires. the brn is ground. the yel is 5 volt ign feed and the blu is the variable wire. hope this helps.
NiCe
corlon
Postby shocar4 » Thu May 15, 2008 7:20 pm
so then is the yellow the voltage output wire then?
shocar4
Postby no_escape » Thu May 15, 2008 7:50 pm
From how corlon explained it... it seems as if the yellow is the voltage feeding the TPS and the blue is the wire that sends a voltage signal to the ECU that tells the ECU what the Throttle Position is.
Correct me if I'm wrong someone.
no_escape
Postby corlon » Fri May 16, 2008 9:54 am
sounds like you need the blue wire.
NiCe
corlon
Postby shocar4 » Fri May 16, 2008 10:09 am
thanks guys!
shocar4
