SolaraGuy.com • View topic - High ga prices means switching grades?
Postby Grnarowana » Mon May 19, 2008 4:23 pm
With the high rise in gas prices, people are trying to minimize their gas usages and maybe even changing grade fuel levels.
Did anyone change their grade level because of the gas prices and did you see any differences in MPG?
I use Premium and might just go regular since the price of gas is just ridiculous, but I'm afraid it might hurt my MPG.
I run a 1999 v6 manual and get about 475 miles on a full tank on highway and if it's 75% highway and 25% street I run about 350 miles on a full tank.
If I switch to lower grade fuel will it dramatically decrease my MPG and performance?
And is it worth the switch?
Has anyone tried it before? It would be great to hear some word from this.
Grnarowana
Postby Americanctm10 » Mon May 19, 2008 4:33 pm
Are you boosted?
If your not then why are you using Premium?
Americanctm10
Postby ThatVietGuy » Mon May 19, 2008 5:01 pm
I've seen zero difference between using 87 and 91.
Of course, it's not zero, but it so minute it doesn't matter.
ThatVietGuy
Postby bassthrive » Mon May 19, 2008 9:19 pm
I used to fuel with mid-grade, now I use 87.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Grnarowana » Mon May 19, 2008 9:25 pm
nope, not boosted. I guess its a psychological thing. I guess I'll try 87 and see how it goes.
Grnarowana
Postby Toy1mzfe » Mon May 19, 2008 9:56 pm
I went from 91 to 89.
not too sure if it did or not. It felt less responsive but that could be a mind game thing.
Postby Got2XLR8 NYX » Mon May 19, 2008 9:57 pm
I ran 87 on my V6 5SP and on a full tank drove 500 miles all highway from ATL to Orlando so I don't think octane grade makes a difference. If anything I was amazed that I even pulled 500 on that 1 tank.
5Speed 2000 SC V6 @ 4.5PSI
Got2XLR8 NYX
Postby gnegroni » Mon May 19, 2008 10:03 pm
What does the owners manual say? Gen2 V6 owners manual says 91 for better performance if I'm not mistaken... if it doesn't say so, just put 87. I used to have 93 when my 2005 4-cyl was new, thinking it was better for power and mileage...but after more than a year of using 87, can't seem to recall ANY difference.
PS The best thing I did was switching to Mobil-1, but that is a completely different topic...which DOES bring better economy if you use regular oil.
gnegroni
Postby kingkakyle » Mon May 19, 2008 10:46 pm
yep the 3mz says u should use 91 for more performance but 87 is fine with no knocking
soooooooooooooo for the 1mz 87 should be fine
also its a toyota.....MOST of them only require 87 anyways
Postby Grnarowana » Thu May 29, 2008 8:45 am
I don't know, but for some reason I'm getting better mileage with 87.
My car is fully stock with a drop in K&N. I use mobil 1 full synthetic 10w30 @ 125.5K miles. And i switched from 91 to 87, and I'm getting better mpg. Usually at half a tank i'm at 150-155 miles, but now I'm ranging at 180-190 miles. And this is all 75% highway and 25% streets.
What gives? Is it because higher grades burn more cleaner?
Grnarowana
Postby no_escape » Thu May 29, 2008 8:50 am
You should get better mileage with 87. 87 doesn't burn as hot as 91. Higher oct., hotter, cleaner burn.
no_escape
Postby TMMK Toy » Thu May 29, 2008 3:12 pm
91 is required for the 1mz but if you use lower the knock sensors will just retard timing. Most pumps out here dont offer 91, its 87, 89, or 93. So I run 93. I'm shocked at the mileage numbers you guys are posting. I generally get 220-240 on half a tank and a lil past 3/4 I've gotten close to 400. Those numbers generally are 23-24 mpg. I do a lot of highway driving but cruise at 80 and I drive rather aggresively. Hell, I thought my mileage was crappy compared to other people with 5 speed 1mzs.
Since I've had body work done on my car I noticed a slight gain in miles at 1/4 tank and even still a lil bit at 1/2 way. I have to drive to work tomorrow so I'll be filling up before heading up to the meet Saturday and curious to see if I am getting better milage. The body work was to replace a torn front bumper skin, so I think the damaged one may have actually been creating some drag robbing me of easier highway cruising.
TMMK Toy
Postby DaZanY4002 » Thu May 29, 2008 3:30 pm
I use 87 Chevron/Texaco only. I don't see the need for higher.
Also, I think a few months back in the manual, I read 87 octane for Gen 1's.
DaZanY4002
Postby atclate » Thu May 29, 2008 4:25 pm
I took a drive to riverside earlier, then to LA, then back to San Diego, total of about 330 miles. I filled the tank at the end of the day and found myself at 25.4 mpg. (13 Gallons) This time I was using 87, and it's the best mileage I've ever gotten.
I raced my car a little today, but I found myself passed by a Buick SUV even after bottoming the gas pedal >_<
Man my car suck.... bad gas mileage but no power... grrrh...
For sale: Injen SRI, Randy's CAI extension, TRD Supercharger, TRD RSB, Jim's Torque Rod, 2003 Solara SLE with TRD Body Kit
atclate
Postby Jakecallun20 » Thu May 29, 2008 8:51 pm
87 is fine, my car has been run on 87 octane since it was brand new in 1999. No problems (I have 1MZ btw)
