SolaraGuy.com • View topic - AC question
AC question
AC question
Postby Grnarowana » Mon May 19, 2008 10:44 pm
It starting to heat up in SoCAL and I thought it might be time to rejuvenate my AC. I bought the car in 2003 and its a 1999. Since than I never charged the AC. How much would this run and where should i get it? Toyota, Jiffy Lube?
Grnarowana
Postby Dawgz » Tue May 20, 2008 10:09 am
Take it to toyota, never take it to Jiffy Lube
Re: AC question
Postby Gregtrd » Tue May 20, 2008 1:17 pm
Grnarowana wrote:It starting to heat up in SoCAL and I thought it might be time to rejuvenate my AC. I bought the car in 2003 and its a 1999. Since than I never charged the AC. How much would this run and where should i get it? Toyota, Jiffy Lube?
i'll refill it for $65, im ase certified for ac and have my own ac machine. i live in fontana ca.
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Postby Chinky420 » Tue May 20, 2008 1:31 pm
buy a haynes manual and a recharge kit. it's easy, unless you have a known refrigerant leak....in which case, i can't be helpful.
but if you're not actively leaking the freon, then just buy a charger at wal-mart or autozone, and then a haynes manual for the camry (also at autozone) and recharge it yourself.
it's not that hard (if you can put air in your tires, then you should be able to charge an A/C up).
total, for the manual, the charging hardware, and two cans of r134 refrigerant, it should only run you about $25-40 USD
the manual is really not necessary, but i figure you'd want it since you're only supposed to fill one of the two valves (i forget if it's the high pressure or the low pressure end, that you're supposed to fill).
Chinky420
Postby alltrac92 » Thu May 22, 2008 5:35 pm
Chinky420 wrote: but i figure you'd want it since you're only supposed to fill one of the two valves (i forget if it's the high pressure or the low pressure end, that you're supposed to fill).
Always charge/fill from the low side fitting.
alltrac92
Postby RFTL08 » Mon Apr 27, 2009 2:01 pm
does anyojne know how much r-134 the solara holds? or how much pressure? i will be doing this tonight
RFTL08
Postby ASG14 » Mon Apr 27, 2009 2:15 pm
If you have a 1999 Solara and the refidgerant is out, you likely have a leak. I'd have dye put in the system as well. Send a PM to GregTRD.
ASG14
Postby RFTL08 » Mon Apr 27, 2009 2:29 pm
its never had the ac recharged since july of 2000 when it was bought new... it still cools just not very well. does anyone know what the r-134 capacity or pressure should be on the 2000 solara so i can pick up a can of r134 on the way home
RFTL08
Postby D-money » Mon Apr 27, 2009 5:46 pm
i used a ac recharge kit from pepboys it was 20 bucks and damn it gets cold now
D-money
