SolaraGuy.com • View topic - Modifying my stock 03 lara tails
Postby knightbird123 » Sat May 24, 2008 5:44 am
Does anyone know how to remove the amber film from the stock taillights. I want my taillights to appear as shown in the below link. I need some instructions on how to do this mod.
http://www.cardomain.com/member_pages/s ... 3_full.jpg
This was done by krawzyazn. Krawzyazn how did you do that mod? It looks great
knightbird123
Postby DrLove » Mon May 26, 2008 12:05 pm
I saw on SG that it's pretty hard (impossible) to open the taillights in 2 pieces without destoy them..that's why I didn't try a LED taillight conversion, I want to be able to put back my gen taillights when I will resell the car, my dark altezza will not be appreciate from older people than me.
Mazda 6 2010 6 speed black GS
DrLove
Postby SpeedySolara » Sat May 31, 2008 11:00 am
I've always wanted to make that mod but because the lights are put together like the corners, usually they break. I bought an extra set that I'm going to experiment with. If my methods work, I will take pictures and show you how I did it. For right now, I think I'm going to grab a sharp razor blade and simply start cutting. I will glue them back afterwards.
ANY BETTER IDEAS?
SpeedySolara
Postby krawzyazn » Sat May 31, 2008 11:05 am
good luck! I did mine but cutting dont use a razor your gonna hurt yourself!
Postby LatinUSMC » Sat May 31, 2008 1:18 pm
DrLove wrote:I saw on SG that it's pretty hard (impossible) to open the taillights in 2 pieces without destoy them.
X2
BUT GOOD LUCK TRYING TO PRY THE OPEN
i have alteazza and new gen1 tails in storage incase you need them.... :P
LatinUSMC
Postby SpeedySolara » Sun Jun 01, 2008 4:07 pm
So I got this project jump started once and for all. The clear cover is off with a minor crack which truly could've been avoided if I didn't rush. I'm going to take pictures when I open up the other tail light. If you want to try this now, I recommend to start prying open the tail lights where there are wider gaps. The hardest area to pry open is the black portion, the rest is easy!
SpeedySolara
