Resetting ECU CEL Car Dies at Idle Now
Hello everyone, 2003 Solara 2.4 liter auto with 100,000 miles here. I just recently threw a CEL with a code of P0171. I checked for some leaking or bad air hoses, and found one that wasnt on completely right after the MAF Sensor. I reset the code by taking the positive battery terminal off for 30 minutes to try and see if the car will still throw another CEL, and now my car dies at idle.
You can start it, rev it up, drive it, whatever but as soon as you depress the brake and come to a stop, the car drops below 350 rpms and dies. If you start the car and dont depress the gas, the RPM's drop and the car dies too. I have reset the ECU before the same way, and the car usually will do the same thing and idle really roughly for about 5-10 minutes, but then it returns back to normal. It has been two days of driving now and it is still doing the same thing, and it seems worse.
There is no CEL on, the car seems to run perfect and get good gas mileage, but now it just idles so low that it wont continue to run.
Does anyone have any idea on what might be causing my problem? Is there a way to adjust the Idle manually on the 2az-fe engine?
Any help is greatly appreciated...
- sethster
- Just Licensed SolaraGuy
