SolaraGuy.com • View topic - My solara v6 engine rotate but won't start~~~~~~~~~~~~~~~~~
Postby solaragreen » Fri May 30, 2008 3:20 pm
I got a solara v6,the engine turns over but won't start,checked the CAS,CRANK sensor,PCM and the fuel pump no problem.
But no spark from the spark plug,checked the wire to the coil from the igniter no power at all.
The mechanic checked the wiring harness for he said is fine.
What kind of problems would it be??
I'm getting crazy about this car just got it 1 month ago.....
Please help me folks......
I live in San Francisco,does anyone known any good mechanic in bay area.
My email is :sf_plus@yahoo.com
solaragreen
Postby DaTwUnKrAziEpInOy » Fri May 30, 2008 4:44 pm
Any Check Engine Light ? If you do get the codes read. When did you car start doing this ? Just trying to understand and try to help ya out.
DaTwUnKrAziEpInOy
Postby solaragreen » Fri May 30, 2008 4:56 pm
DaTwUnKrAziEpInOy wrote:Any Check Engine Light ? If you do get the codes read. When did you car start doing this ? Just trying to understand and try to help ya out.
The engine won't start,can't see any code......Since last Wednesday,it is still in the shop,I don't see any code before it happens...
solaragreen
Postby DaTwUnKrAziEpInOy » Sun Jun 01, 2008 1:08 am
Could be your coil packs are bad if you're not getting any spark energy. Can you describe what the engine sounds or does while you're trying to start the car?
DaTwUnKrAziEpInOy
