SolaraGuy.com • View topic - Will the OEM Alarm system prevent a starting problem?
Postby solaragreen » Fri May 30, 2008 4:53 pm
My solara alarm system is not working,the led was stay on when i leave the car,right now the led it's flashing after i leave the car,even i put the key in....
Could someone tell me what is the normal led working look like?
thanks
solaragreen
Postby woa_its_j3ff » Fri May 30, 2008 5:02 pm
uhhh... umm well when i had the factory alarm, after i locked the doors etc, it would just blink. after i used the key fob and unlocked the doors with it, it would stop blinking.
Postby solaragreen » Fri May 30, 2008 5:09 pm
woa_its_j3ff wrote:uhhh... umm well when i had the factory alarm, after i locked the doors etc, it would just blink. after i used the key fob and unlocked the doors with it, it would stop blinking.
So if the led light flashing am i possible to start the engine...????Because the alarm sysem has no response even i changed the battery...how can i reset the alarm system and how do i know my alarm system is still working???
thanks
solaragreen
Postby woa_its_j3ff » Fri May 30, 2008 5:22 pm
let me check when I leave the house in 10 minutes, ill get back to you within 1-2 hours when i get back.
Postby solaragreen » Fri May 30, 2008 5:26 pm
woa_its_j3ff wrote:let me check when I leave the house in 10 minutes, ill get back to you within 1-2 hours when i get back.
thanks
solaragreen
