SolaraGuy.com • View topic - weird grinding sound???
Postby woa_its_j3ff » Wed Jun 04, 2008 9:35 pm
Okay this just happened today, it sounds like a weird grinding sound, scraping to be more exact, and its coming from the rear. I look under the car but there is nothing loose so I dont knwo what the deal is,. the only recent stuff I did was change my rear rotors, front pads, etc.. and I check those today and everything seems fine, what can be the problem??
Oh I put on rear spacers too but thats not a rubbing sound I'm hearing so.. and they are on tight..
Postby Toy1mzfe » Wed Jun 04, 2008 9:47 pm
When does it grind? While breaking or just crusing?
Does it increase when you drive faster or is it constant.
Re: weird grinding sound???
Postby Gregtrd » Wed Jun 04, 2008 9:49 pm
i know what it is, take the tire off the side that you hear scraping, theres a shield that gos around the rotor make sure its not rubbing on the rotor, just use your hand and bent it away from the rotor, im pretty sure that your problem,
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Postby woa_its_j3ff » Wed Jun 04, 2008 9:57 pm
^ greg, does this happen only when you brake? cuz mine happnes I think only when I brake. maybe once in a very few times today when I was driving very very slow from a brake point..??
if that is the problem, any idea how this coulda happened? just road debris?? :o
Postby Gregtrd » Wed Jun 04, 2008 10:04 pm
woa_its_j3ff wrote:^ greg, does this happen only when you brake? cuz mine happnes I think only when I brake. maybe once in a very few times today when I was driving very very slow from a brake point..??
since you said that you replaced the rotors, sometimes that shield might get bent enougn to scape the rotor, the way you describe the sound thats what i suspect.
Gregtrd
Postby woa_its_j3ff » Wed Jun 04, 2008 10:46 pm
ok thanks Gabe. Will check it out. Will update later.
Postby Toy1mzfe » Wed Jun 04, 2008 11:32 pm
old pads new rotors?
Postby Somedude » Thu Jun 05, 2008 8:20 am
Make sure your rear sway bar is lubed.
Somedude
Postby woa_its_j3ff » Thu Jun 05, 2008 8:36 am
Toy1mzfe wrote:old pads new rotors?
my rear pads are fine.
and my rear sway bar got relubed when i did my rear rotors.
Postby Gregtrd » Thu Jun 05, 2008 10:59 pm
so did you find the problem?
Gregtrd
Postby woa_its_j3ff » Thu Jun 05, 2008 11:01 pm
I checked the shields they both seemed fine I didnt see any bendage of any kind but it surely sounds like it comes from the rear wheels and its not rubbing and nothing is cambered..
its very odd..
and I THINK .. it only happens when im slowing down from like 10 mph to a stop. OR when i turn really slow in a parking lot, and thats only sometimes too. not everytime.
hey
Postby E_funkdoktor » Wed Jun 25, 2008 2:15 pm
i got the same problem... front left brake, any help would be good...
Solara Freak!
E_funkdoktor
