SolaraGuy.com • View topic - DIY Fuel Filter Replacement?
Postby iiifly » Sun Jun 15, 2008 8:07 am
I can't seem to find a DIY for fuel filter replacement on here........
I need to confirm the location, I think I know where it is but for some reason the filter I have is larger than the one I see. Anyone have photos of the location?
thx
iiifly
Postby Dawgz » Sun Jun 15, 2008 8:13 am
the fuel filter is a bit below the MAF sensor on the airbox/intake.
Its bolted onto the driver side area.
an easier way is to follow the lines from the fuel rails down to the filter itself.
Postby JavaJoe_2 » Sun Jun 15, 2008 8:19 am
Follow the fuel rails to the fuel line and down to the filter.
Drivers side, under (approx. 12-18") the Brake master cylinder on the inside frame rail.
It should be a 14mm for the under side line and I think a 17mm (?) for the filter bottom, be sure to use a hydraulic line wrench if you have it.
On the top remove the cover to reveal a plastic clip, squeeze together and it pops out.
You line will have a residual pressure, so have something to protect yourself and catch the gas.
Got Boost?? :sweet:
JavaJoe_2
Postby iiifly » Sun Jun 15, 2008 8:28 am
That's where I though it was. I bought a WIX filter, but it's way bigger than the one that's there. I know it probably could be installed, but is this normal??
iiifly
Postby SolaraPete » Sun Jun 15, 2008 9:52 am
Just put a WIX fuel filter on my car last weekend - it fit right back in the factory bracket. You sure they sold you the correct filter?
SolaraPete
