SolaraGuy.com • View topic - Radiator loose...
Radiator loose...
Radiator loose...
Postby mazen222 » Tue Jun 24, 2008 9:13 am
is it sormal that the radiator is loose? i discovered this last week when i was checking out the engine.... i can move the radiator by approx 5mm max towards the front/back...
it is held by two rubber screws that i have no idea how to squeeze and also by two other hooks that i prefer not to play with...
can u guys tell me if this is normal and if not how should i stablize it?
Thanks!
mazen222
Postby Dawgz » Tue Jun 24, 2008 9:20 am
it does have some play, it rests in those rubber mounts ontop which allows it 'some' movement.
Postby SleeperSolara » Tue Jun 24, 2008 1:05 pm
It's normal for alittle movement of the radiator.
