SolaraGuy.com • View topic - O2 Sensor PO135
O2 Sensor PO135
O2 Sensor PO135
Postby Sap Z » Wed Jun 25, 2008 6:41 am
Hey guys - Its been forever since I've been on here.
I'm looking for some help. I've used the search function but had no luck.
My check engine light had been on so I got it checked my autozone for free. It came back with the O2 sensor code so i bought a bosch and for it swtiched out.
The light came back on the next day, and it gave a diff code this time ( don't remember what it is).But it basically said that either the fuse was bad or the wiring was bad etc
So i got another new sensor thinking it was a bad part and same thing again.
I need help. any ideas?
Thanks!
SapZ
V6 SE DWP
Sap Z
Postby bassthrive » Wed Jun 25, 2008 8:39 am
1) Your V6 has two upstream sensors front and back. Did you replace the correct one? (if one fails, the second is not far behind, i recommend doing both)
2) If your car is CA emissions compliant (pre-cats) you need air/fuel sensors, not O2 sensors.
3) Bosch sucks, go with denso.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Gregtrd » Wed Jun 25, 2008 10:06 pm
bassthrive wrote:1) Your V6 has two upstream sensors front and back. Did you replace the correct one? (if one fails, the second is not far behind, i recommend doing both)
im petty sure that cali spec.(precat) is o2 sensor
and fed. spec (no precats)is air/fuel.
most 1999 and up toyota's are air/fuel sensors
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Postby Mole » Wed Jun 25, 2008 11:11 pm
CA is not the windy city... based on OP's location.
Postby Brettboy » Thu Jun 26, 2008 7:36 am
I had the po135, Autozone told me it was the front sensor...Replaced it and the light came back on...Then I did more research and found out that po135 is the back sensor close to the firewall. Changed it and voila. I used bosch sensors and they work just fine.
99' SE V6 Black Metallic
Customized grille, 18 inch ADR rims, Injen intake, K&N Filter, 20% tint, Iggee custom seat covers, teins, tokicos
Brettboy
Postby Sap Z » Thu Jun 26, 2008 7:50 am
wait wait wait - po135 is by the wall (as in the dashboard of the car) and not the headlights?
wTF those dum retards?!?!
SapZ
V6 SE DWP
Sap Z
Postby PXLpainter » Thu Jun 26, 2008 8:21 am
*Edit: it pays to read ALL the posts completely - geeze...
yes, P0135 is rear sensor (Bank 1 Sensor 1) and P0136 is front sensor (Bank 1 Sensor 2)
Postby Chinky420 » Thu Jun 26, 2008 9:50 am
ok,
P0135 = rear sensor (between firewall and engine block). it's functionally similar to the o2 sensor that is right in the front of the engine bay (the easily acceable one).
if fed spec then it's o2 sensor, if cali-spec then it's an A/F sensor (i'm almost positive on this one, gregtrd)
bosch is hit or miss with the solara's. it's best to stay with denso as the brand. from the sound of the second code being thrown (diff code, diff symtoms), i'm guessing the car didnt like the bosch wiring or configuration or something. if you changed the correct sensor, and the wiring on the sensor looked good, then try unplugging the battery for another 10 minutes and see if the problem comes back. if you get the second (newer) code again, then you are going to want to buy denso sensors instead of bosch.
GL
Chinky420
Postby bassthrive » Thu Jun 26, 2008 3:20 pm
Chinky420 wrote:if fed spec then it's o2 sensor, if cali-spec then it's an A/F sensor (i'm almost positive on this one, gregtrd)
You are 100% right.
Also, you don't have to be in CA to have CA spec emissions. I bought my Solara in New York. Sucks that I had to pay for the more expensive a/f sensors when they "expired".
My writeup...
http://www.solaraguy.com/viewtopic.php?t=38603
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
