SolaraGuy.com • View topic - Intake manifold gasket ?
Postby Midias » Sun Jun 29, 2008 7:34 pm
I was wondering for those of you who have replaced your knock sensor did you need to replace your manifold gaskets or are they the reusable metal kind?
Postby CASTRO » Sun Jun 29, 2008 7:41 pm
nope i didnt. its metal
CASTRO
Postby Dawgz » Sun Jun 29, 2008 8:11 pm
i replaced mine when i put the sc on...since the gasket was original...
since urs has some milage on it, u might as well replace it, its about 25$ at the dealership...
Postby hskrsolara » Sun Jun 29, 2008 8:34 pm
when I pulled my s/c, my metal gasket was still in great shape...but, for peace of mind, I would replace it if I were you.
hskrsolara
Postby JavaJoe_2 » Sun Jun 29, 2008 8:45 pm
Nope, many times used again and again.
Anyway, it's right on top if you need to replace it.
Got Boost?? :sweet:
JavaJoe_2
Postby alltrac92 » Sun Jun 29, 2008 9:32 pm
The plenum gasket is two pieces sandwich together.
Part number 17176-62030 list price is $9.79 I paid $6.48 for mine.
alltrac92
Postby Eye8Pussies » Sun Jun 29, 2008 10:18 pm
best to replace it
mostly because the block's coolant lines go through the gasket...and the rubber usually sticks to the manifold or block when you take the gasket off
Postby Eye8Pussies » Sun Jun 29, 2008 10:19 pm
and lol...he's not asking about the plenum gasket, which can be reused....but the INTAKE MANIFOLD gasket...
if it's not replaced, then coolant leaks are almost a sure bet unless the gasket was just replaced
