SolaraGuy.com • View topic - My new problem (leak in trunk)
Postby Gangis » Mon Jun 30, 2008 11:00 am
Finally found the source of the weird smell in my car - I had 3 quarts worth of standing water in the trunk. Mostly in that side compartment, but there was about a quart in the spare tire storage area, two in that side compartment. I pulled out most of the lining, sprayed water over the rear half of the car (with the trunk closed, of course.)
I traced the leak to the ledge where the rear support frame for the convertible rests. Apparently when I put the new top on (went from tan to black) I didn't seal it properly. Oops. I'm trying to figure out how to fix it without disassembling the top partially again. Any ideas?
Gangis
Postby Camry Racing » Mon Jun 30, 2008 11:09 am
same problem in my camry but the other side
Camry Racing
Postby no_escape » Mon Jun 30, 2008 11:50 am
I also found the same spot where water, dirt, and grime stood. However mine was more black and oil-like.
I put an extra qt of oil on each side in a sack. So when I need to put oil in my car, I'll remember it's there and I can check for any standing water or oil.
no_escape
Postby 1st Gen Sol » Mon Jun 30, 2008 4:09 pm
Check the rubber seals that go around the trunk to keep water out, it can possibly be that or the water reservoir could be clogged.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby Gangis » Tue Jul 01, 2008 1:13 pm
1st Gen Sol wrote:Check the rubber seals that go around the trunk to keep water out, it can possibly be that or the water reservoir could be clogged.
Nah, I know what the problem is. I just want to know if anybody knows what I can use to seal the inner top back onto the ledge.
Gangis
