SolaraGuy.com • View topic - Cold air only out Driver Vents
Postby frohboy33 » Tue Jul 01, 2008 3:03 pm
My AC started blowing cold air out the the driver side vents only. The passenger vents are blowing warmer air that smells like its got humidity in it. Do you think it just needs a recharge or is it a bigger problem? Its a 2003 with 50000 miles on it.
Matt
2003 Solara SE
I4 75,000 miles
TRD kit
frohboy33
Postby Akfahad » Tue Jul 01, 2008 3:09 pm
mine did that before, probably just needs a recharge, but since mine was considerably older, I had to replace the condenser, etc.
Postby nj99solara » Wed Jul 02, 2008 4:35 pm
I had the same problem about a month and a half ago, and as the weeks went by it started to get warmer gradually and then saturday it wouldn't get cold at all so I recharged it on sunday and now it works fine and ice cold.
-4500k HID Bi-xenon kit
-4500k HID Fogs
-5% Tint in rear
-Tinted Stock Taillights
-Shaved Emblems
nj99solara
Postby frohboy33 » Mon Jul 07, 2008 4:22 pm
Well I found out its NOT the freon level. I bought a kit and the pressure is just fine, so I didnt add any. Anybody have any other suggestions on what I may want to look into? Is there a dampener that switches between the vent and AC that may be bad? Any help or suggestions are appreciated.
Matt
2003 Solara SE
I4 75,000 miles
TRD kit
frohboy33
Postby frohboy33 » Mon Jul 07, 2008 10:14 pm
I checked the air mix damper control cable and it is just fine. It closes all the way, so I can rule that out. Anybody with any experience working on the ventilation system on our cars?
Matt
2003 Solara SE
I4 75,000 miles
TRD kit
frohboy33
Postby Akfahad » Tue Jul 08, 2008 6:05 am
not any real experience, but it could be the unit itself... :(
Postby frohboy33 » Tue Jul 08, 2008 2:35 pm
Thanks for the reply, I check everything out and the condensor and the rest of the AC assembly seem to check out fine. I think its gotta be something where the outside air mixes with the AC air, but I cant find anywhere where there is a mixer door or anything. The air on the passenger side gets down to about 62 degrees. Its weird how one side works great and the other doesnt.
Matt
2003 Solara SE
I4 75,000 miles
TRD kit
frohboy33
Postby pearlydiamondwhite » Mon Jul 28, 2008 3:24 pm
mines doing the same thing right now. i am running the freon w/dye in it so i can trace the leak. you said your level wasnt bad, mine drops w/in a month, so i know i have a pretty good leak. the one thing i am not ruling out is the evaporator, which means you need to remove the dash to get to it. i'll re-post after i find out for sure. i just keep recharging so i can at least stay cold.
Diamond White...for more horepower
pearlydiamondwhite
Postby Camry Racing » Mon Jul 28, 2008 5:25 pm
my car once dida that and the guy who repaired it had to remove the whole dash to change a valve or somenthing like that
Camry Racing
Postby Chinky420 » Tue Jul 29, 2008 1:04 pm
mine did that for a while, as well as leaking out freon.
turns out that it was my ac condenser and dryer.
i recommend taking your car to a local auto hvac specialist, and have them do a free estimate. they will usually be able to diagnose, as well as tell you what part(s) are bad.
this is what i did, after taking it to the dealer and the body shop that did some work on it (problem started after getting into a fender bender, so i was making the body shop try and figure it out, even though it's not their specialty).
all in all, it ended up costing about 200 in parts, and about another 50 in labor.
but i don't want to tell you FOR SURE that this is the problem, even though it worked for me. i don't want you to go out and buy parts that may or may not solve the problem.
GL fixing this
Chinky420
